Posts: 208 |
Has anyone upgraded the wireing and made the low beams work with the high beams? I had a cutlas that had this and it was bright but if you could do this on a tour it would be hellabright.
Posts: 193 |
yah, theres instructions in the faq i think.
96 Contour SE, MTX 2 Pioneer 12"s in a bandpass box 2 5x7 Pioneer Plates 2 Stock Speakers 600 watts of blistering radioshack power
Posts: 654 |
Im not sure exactly what you are referring to... If you want the low beams to stay on with the high beems, the "Foglight on with parking lights" will accomplish that. You can also take a bright bulb, file down the tab inside the bulb's socket, and it will plug into the low beam socket, and will not blind other drivers... -Nick
"My family hauler can kick your family hauler's @SS!" ~~~~1999 Contour SE Sport~~~~ -KKM True Rev -Custom cat back Flowmaster exhaust -All Cat's fixed. -SHO Shop Off-Road Y-pipe -Many other Mod's done...
Posts: 515 |
Can't tell for '98, but '99's low beams stay on with high beam normally. I would think the '98 tours are the same.
Fog light fix will allow fogs on with parking lights and when on high beam. Doesn't effect headlights though.
"My Name is Richard. I am a Contouraholic." 1999 SE Sport Duratec ATX Spruce Green; Drop--In K&N Filter; VentShades; Fog Lamp Fix Mod & PIAA510s with Bumper Braces & Stock Type aiming screw mod; PIAA 9006 Super White Headlamps AIWA CDC-MP3 HU; WeatherTech Mats Viper 600ESP w/Remote entry
Posts: 240 |
my low beams turn off when high beams go on. (98 svt)
i was going to work on remedying this.
oh, that brings up another question: for those that have HIDs (real HIDs), they have to ballast up for a second before they actually come on. so what happens when you turn on and off the highs? my meaning is that the highs are not HIDs and the lows that are HIDs go off, so when you turn of the highs, is there a delay before the low HIDs come back on full strength?
-eric
Please: put something meaningful in your post subject! NOT "please readme!". -------------------- "your" is possessive, "you're" is the conjunction that is short for "you are", "there" is for "the dictionary is over THERE", "their" is the possessive one, and "they're" is a conjunction that is short for "they are". have a nice day :rolleyes: -------------------- Silver Frost non-E1 SVT/Contour see my registry/profile: http://contour.org/carprofile/carprofile.cgi?a=display&uid=00004623
Posts: 2,809 |
Originally posted by Contouraholic: Can't tell for '98, but '99's low beams stay on with high beam normally. I would think the '98 tours are the same.
Fog light fix will allow fogs on with parking lights and when on high beam. Doesn't effect headlights though. you are correct.
Posts: 208 |
I want both the headlights to come on with the high beams on this has nothing to do with the fog light fix.
Posts: 164 |
My low beams stay on with my high beams. I think my daughter's 96 Contour's does too.
This didn't have anything to do with daytime running lights on 98's did it?
- Jim
'96 Mystique GS, Ztech - ATX, with CD changer, Sylvania Cool Blues, sunroof, keyless entry, and 9mm blue wires
Posts: 208 |
I have no daytime running lights and the low beams go off when my highs are on
Posts: 9,178 |
99 here and my lows stay on when the high beams are on too.
