Posts: 131 |
Has anybody seen Silver Frost in a spray. All the stores around me stock Dupli-Color and it in not available in a spray. I want to paint my grill trim ring the same as my body color. Any suggestions?
Posts: 2,263 |
well from what ive experienced with a spray can is its very hard to get an even spray, which means very easy for runs to happen..and lots of times even tho the paint code on the can matches the one on your car, they are different shades (at least with my experience). but, since its just a small piece of trim, u dont have much to lose but maybe $5 for a can of paint. i say go for it!
Jim Hahn 1996 T-Red Contour SE 2002 Black Mazda MP5 Latest mods: sho shop off road y-pipe
Posts: 1,075 |
I agree with above. I did this in T-red, and it's a couple shades darker than the car...I would go to a ppg store and see if they can mix a can for you.
Ride: 2000 T-red SE Beats: Kenwood 316S, Alpine MRF200, Orion XTR 6.2, Coustic 400SE Mods: CTA, Magnaflow exhaust, SVT Instrument cluster, Knuaberized doors, side markers, F***ed up painted headlights.
Posts: 164 |
The local VIP auto parts store here carries paint by Plasti-Kote in both 6oz spray and 1oz bottle. You might check www.plasti-kote.com and see if they have the color you need.
- Jim
'96 Mystique GS, Ztech - ATX, with CD changer, Sylvania Cool Blues, sunroof, keyless entry, and 9mm blue wires
Posts: 131 |
Originally posted by JWard: The local VIP auto parts store here carries paint by Plasti-Kote in both 6oz spray and 1oz bottle. You might check www.plasti-kote.com and see if they have the color you need. Cool. Looks they they make it. TS FM 8140* FM 3971* SILVER FROST PEARL M B/C It also states: "A Clear Coat must be used as the finish coat to achieve correct color match." which may be why the red (above)didn't match correctly.
Posts: 365 |
You will never get the right shade . Silver Frost is one of the most difficult colors to match . and to increase this problem by using a spray can. It just wont work. Take this advise from a painter.
98 LX, Eibach`s .... ICWrims / Potenza`s.... Svt kit w /duals... BASF Extreme Ocean paint( complete color change).... Bullit gas door.... Fuba DSM rear mount roof antenna.... Pre 98 trunk.... Blacked out headlamps, W/ Eyebrows.... A6 Side markers.... Shaved antenna and deck lid lock... 4 wheel disc brake conversion.... Magnaflow resinator.... SVT gauge cluster....(Yes the SVT gauge has a O/D light).... Complete mesh grill treatment, Not gutter guard.... Titinaum window tint.... Burgman custom Power window & lock conversion.... More to come as soon as i complete this one. Yeah its a LX but it has a 2.5 and it looks better then your ricer
Posts: 669 |
oh dont listen to extreme lx........what does he know!? :rolleyes:
actually i will atest to whatever alan (extremelx) may have to say........mighty fine work from that man.......
-chris- 96 gl: 18" adr reactions, SVT rear bumper & side-skirts, Magnaflow exhaust, CTA Intake, ACCEL coil, 9mm wires, Kenwood, Blaupunkt, Sony Xplod Mobile ES, OBX pedals w/dead pedal, neons, bnmotorsports gauges, autometer monster tach, and ZAINO!
Posts: 86 |
Use Plasti-kote silver frost code: FM 8140. Remember, a clear coat on top will help the color match better although standing alone it's still very accurate. I've had good luck with it. Perhaps the new coat might be a tad darker but within a few days I noticed the coat matches better. Maybe let the piece fade in the sun a few days after the initial drying.
By the way, it's easy to run the paint. My recommendation is to put on a very light tacky coat before putting on a fuller heavier coat five minutes later. Not necessary to coat the whole area on the first try. Also, shake the can often but remember to do it away from the paint area or you will get a lot of residue splatter from the nozzle.
Some other recommendations, when painting side skirts or bumpers, remember to wash the entire area and more. It takes quite a bit of area to get the touch-up to blend properly. Also, make sure you paint with no breeze in the air or in a garage. Otherwise the overspray goes everywhere.
If you are painting a grille, I'd hang it from a piece of wire.
When painting with a clear coat, there is nothing to it. Just put on a full heavy coat. But be careful, it can run too. Don't over do it.
stock 1998 silver frost SVT E0
Posts: 365 |
Thanks Trick96. I think, but then again i might just have to come up there and break out a can of whoop a$$ on you.....  :rolleyes:
Posts: 2,066 |
Yea I have to say (again) that was some nice work you did on your car Extreme! So how about I drop my car off for about a week and you can make my car look brand new
