Posts: 372 |
I figured I would change them today. Should I go with Motorcraft or something different. How about NGK's?
Ken '00 SE Sport, KKM, Eibach's, Crappy Pioneer 5X7's.
Posts: 878 |
Stock Tips
Even in Stock Class, There Are Ways to Get an Edge on the Competition
story by j.g. pasterjak
Spark Plugs We also did quite a bit of testing with spark plugs on a...twin-cam Neon. At the end of one frustrating day, we learned that, on a Neon anyway, spark plugs don't make a bit of difference. We ran the car first with the NGK plugs that had been installed since we took delivery of the Neon several years ago. We then tested the car with a variety of supposedly "better" plugs-hotter, colder, split electrode, pointy electrode. (No matter what your poison, good plugs cost less than a couple of bucks each.) In this case, all of them produced roughly the same power: within one horsepower, plus or minus. Unfortunately, this was two horsepower shy of where we started with the skanky factory plugs. The skanky factory plugs were quickly reinstalled. Our dyno shop swears by NGK plugs. So, not sure if that's a plug for NGK plugs, or for OEM plugs, since the Neon in the story had OEM NGK's. HTH. Whole Article.
"Function before fashion."
'96 Contour SE
Posts: 731 |
I have Autolite Double Plats in my Zetec and they're great. I'd recommend those if you have the Zetec, but I would shy away from the Platinum +4 plugs. I've heard alot of talk about them frying the ignition system and burning the plugs!
Posts: 1,444 |
get the autolite double plats. ngk does not make double plats which the svt needs. lemme ask this, do u have an svt or zetec. if zetec, get ngk if the application is available
edit: sorry i just read your sig after posting
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 4,899 |
SVT owners complain about Bosch Plat+4, but I have them in my Integra and they work great. But I hear good things about AutoLite Plat, so try those.
Posts: 4,983 |
Spark plugs? We don't need no stinkin' spark plugs!
P. Valdez 1998 VW Jetta TDI 1.9L I4 direct injection turbo diesel 5 speed manual no mods, no money AIM:PackRatTDI My exhaust smells better than yours.
Posts: 28 |
I installed autolite double platinum. Be sure to gap your plugs before installation. The reason that I installed double platinum is because they are supposed to last longer. It is a good idea to add a little silicone dielectric grease to the inside of the spark plug boot. Most parts stores have silicone dielectric grease but it is expensive. The silicone dielectric grease keeps the rubber spark plug boot from sticking to the spark plug. It also keeps water from getting inside the spark plug boot and creating a short to ground.
