You might have a bad wire or burned out bulb(s). Pull the knobs off and see if you see a green light coming from inside. If not, you will need to start tearing stuff apart. Maybe Brad Noon knows what to look for.
Don't try to pull off the fan speed knob... it is retained by a catch that can be released by a small/tiny flat tip (jewelers)screwdriver from the backside.
