#142838 03/07/02 07:25 AM
Alex T. Offline OP
I got the info to do the fog light mod, my question is that I'm seeing alot of picture with the parking lights on with fogs and the daytime lights are not runing, is that part of the mod in wiring or is there some fuse to pull to elimate the daytime runing lights.
Thanks,
1999 Silver Frost Contour SVT
2690 of 2760 Born 08/13/1999
Sony Mobile ES CDX-C90 Deck
6 1/2 Infinity Kappa Perfect mid & tweet set, 2 12" Infinity Kappa Perfects JBL P.600.1 for Bass, P.180.2 for front stage.
#142839 03/07/02 08:01 AM
I didn't think the SVTs got the running lights but maybe they did. I'm assuming of course you're talking about the mod on your car. If you do have DRLs(daytime running lights)there is a tall white relay in the engine bay fuse box that needs to be removed. You'll need to install a bar across two of the terminals however or else your lights wont come on at all. IIRC the terminals are the ones to the drive and passenger side of the box. Meaning, if you're looking down into the fuse box from the front of the car you need to add a jumper of some sort(inch of wire, two connectors)in between the left and right terminals where the relay used to be. HTH. laugh
#142840 03/07/02 08:08 AM
Alex T. Offline OP
Thanks, it's because it's law in Canada that cars after a certain year have to have DRL's, thanks alot for the how to.
#142841 03/07/02 08:11 AM
Oh right, guess I should have read where you were from. It all would've made since then. wink BTW, just glad I could help. You might try getting the actual Ford buss bar from a dealer(or wrecked car)just to be safe. Its a fairly stout piece of metal considering it directs the current for the headlightseek laugh
#142842 03/07/02 05:44 PM
E
E
My Tour had DRL and I live in MN!!!!! I just diconnected them from the headlights when I put on my aftermarket driving lights. Now my driving lights are my DRL's.
The fuse for the DRL's, I believe, is the ignition fuse under the hood. Don't quote me but I think this is correct. It shoudl be in the manual.
'95 Contour GL, zetec mtx, drop in K&N, exhaust res removed, 4 10" Kenwoods powered by 1000W Visonik amp, 4 5"x7"/6"x8" Visoniks
"Buy American or apply for Japanese welfare."
www.geocities.com/fordcontour05/contour.html
#142843 03/07/02 05:46 PM
If you want to be able to use your fogs and Parking lights without your head lights, the link below is a How-To.
http://contour.org/mods/mods.cgi?s=howto&display=fogconv
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
#142844 03/07/02 06:01 PM
DRLs really don't complicate the issue....but the fog lamp mod if you have DRLs is somewhat pointless.
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
