Posts: 345 |
Would someone be so kind as to re-post the bracket photos and the install info? Thanks, AL
Red '98 SVT E0 3098/6535 KKM, Elizabethan EGR Plate, TH fix OMP front brace Hightower rear brace DMD B&M with reverse lockout disabled and centering spring removed Mobil 1 oil and trans fluid A6 Side Markers, Optima orange, Horn recontent Painted Sail Panels VooDoo Knob and pedals, RogerR deadpedal Blau Houston & CD changer Cup holders that work Donnelly mirror BAT Sill Plates and a Bullitt fuel door
Posts: 345 |
Posts: 187 |
I wouldn't use those, you break the paint and it will rust. Here is my instruction w/o body damage. http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic&f=7&t=001994&p=
-Bill D.- 1998 Silver SVT #862 Mods: MOMO Racers 7.5x17, 17X215/45 Potenza RE730, Color matched GTS Headlight Covers, OPM Strut Bar, K&N Filter, Hood Lifts, Eibach Springs, Alpine CDA-7875 w/4 Polk EX & 2 Jensen Tweeters, B&M Short Shifter, Bullitt Aluminum Fuel Door, Billet Aluminum Control Knobs and SVT Lighter, Aluminim E Brake Handle, Borla Exhaust, SHO Y-pipe, Aussie Bar, Splitter (ready to install), Indiglo Instruments
Posts: 345 |
Bill, Thanks for the info. Comparing the two procedures - Am I correct that your procedure retains the 'boot' of the stock door assembly. The Bullitt mounting ring is fastened to the flange of the boot rather than using the two brackets and eliminating the boot?
AL
