Originally posted by jcboeckl:
Ok I have read a ton of posts on this subject and everyone seems to have a different take on what year has which type of cupholders?
I think I understand that the MTX came with 1 and the ATX came with 2. Then I started hearing about one which you pull/slide up and is of better build quality.
Also I have looked on www.car-parts.com and they don't have a listing for console, is it under something else. Doesn't seem to be anything even remotely close either?
Also anything else I should know feel free to add!
ThanksSorry, not sure about the cupholder thing...never could figure out which model came with what, but I may be able to help out with some other questions.
1)you can use either MTX or ATX consoles. If you get an ATX you will need to call bill jenkins and order the MTX surround, it goes for ~20 IIRC
2)There is no way to really look up the console on car-part.com so I just look for any interior piece of the tour and then call the junkyard and ask if they have a center console available. I've been quoted about $70 from a couple places, one guy got his for $40 so I guess there are deals to had
3)Make sure you get the panels that cover up the all the ducts behind the console. When I originally ordered my console they sent it without the panels and I ended up having to argue with the damn people all day, finally got em though!
4)Before you paint the console make sure to use a good vinyl/interior cleaner. This part is really crucial because it removes all the oils and residue from the console and gives the paint a good surface to stick to. I found mine at a local automotive paint store.
HTH
