W
wilo Offline OP
W
i was looking for something like this
I was trying to find some thing to replace the hood liner i have because it's starting to sag and fall apart mad .
Popular opinion here is that the hood liner keeps the engine bay too warm.
My car did not come with one (Darn Decontenting) so it is not "needed" per se.
FWIW, I think JCWhitney sells stuff like that.
"My Name is Richard. I am a Contouraholic."
1999 SE Sport Duratec ATX Spruce Green; Drop--In K&N Filter; VentShades;
Fog Lamp Fix Mod & PIAA510s with Bumper Braces & Stock Type aiming screw mod;
PIAA 9006 Super White Headlamps
AIWA CDC-MP3 HU; WeatherTech Mats
Viper 600ESP w/Remote entry
If you really want one, it's made by Dynamat and you can get one at any car audio shop........
99' Silver Frost SVT
18" Racing Hart C2's
Color matched Headlight covers
Ding guards removed
Custom intake
B&M Short Shifter
Koni's and Ground controls
NGK Iridium plugs
Hoodliner = bad if you're using a non-stock intake system!
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
E
E
Mine came without one (or someone already removed it). I haven't had any issues with the engine being too cold. The only real reason I could see having it would be to cut down on engine noise. If that is the case, like Superperk said, Dynamat makes some. Make sure you tell them that you are using it as a hood liner so they will sell you the correct matting. There is one that is lined, like the pic to insulate slightly.
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
E
E
I never had one on my car(must of came as an option :rolleyes: ) Since my car is probably one of the closest to base on here. But the car runs cooler than most. Even though zetec gauges are all different.
'95 Contour GL, zetec mtx, drop in K&N, exhaust res removed, 4 10" Kenwoods powered by 1000W Visonik amp, 4 5"x7"/6"x8" Visoniks
"Buy American or apply for Japanese welfare."
www.geocities.com/fordcontour05/contour.html
W
wilo Offline OP
W
I just wanted to protect the paint on my hood from too much heat comeing from the engine. I will take it off today maybe it's not too loud if it is I going to put it back on until it falls off.
I am thinking of getting a hoodliner too.
I probably will go with Cascade instead of Dynamate.
Check this http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=5;t=002361
Regards,
Kirill
98.5 Contour SE Silver Frost (powered by Duratec 2.5L)
Nakamichi CD-45Z -> Phoenix Gold XS4300 -> Infinity Kappa 693.3i
\_ Blaupunkt ODx694
W
wilo Offline OP
W
I am going to order this one cause I don't need the dynamat and this will do about the same.
web page
