#142610 02/25/02 03:04 AM
Hi,
Has anyone here ever toyed with the (trunk plate holder/trunk plate light) on a 95 GL. The reason I asked is because I bought my car used and the bolts in the liscense plate that hold it up were striped, I broke the end of one off. Then I took the piece out of the trunk and only discovered that there were plugs behind the bolts. If I were to drill the thing out can I get new plugs or should I just forget about it and head to the junkyard(there's a crack behind the plate). So what should I do? See Ford, drill through and get a plug, or go scrapping?
Thanks in advance. smile
'95 GL ATX
Midnight Red but soon to be Black!
No Mods so far except audio...YET
Next Up:
*Paint Job
*Wheels + Tires
White Knuckle Tight
#142611 02/25/02 03:27 AM
I drilled mine out, and replaced it with license plate plastic bolts. The design on the Ford ones is the worst ever.
My experience
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
#142612 02/25/02 04:53 AM
Their is a fix. Ask Bill Jenkins about the kit. It's like $7 I think. You drill out the old holes and RTV a plastic strip onto it. Cheap fix.
"If you're pushing crazy I'm all full up here."
{Black '96 Contour SE MTX w/ over 126k on the clock}
· Get the skinny here.
· Need a 96-00 Ford Service Manual on CDROM?
#142613 02/27/02 01:40 AM
I
I
just dont get the svt license plate holder from ebay. i got it and its too tall to fit. mad i do have a 98 svt though. im not sure what the size of the pre 98 ones are.
on the road of life there are fast cars, and then there are hondas.
#142614 02/27/02 03:20 AM
I'm Good to go now guys! 35$CDN from my local u-pull, even my color too! He had tonnes of them too, it felt good after going to ford and having a minor heartattack after finding out each light was 70$CDN apiece. Not a bad idea afterall, I think i'll visit the junkyard more often. laugh
'95 GL ATX
Next Up:
*Paint Job
*Wheels + Tires
White Knuckle Tight
#142615 02/28/02 04:40 AM
E
E
The pre-98 ones look an aweful lot like the ones that come on a Mystique, they are just body color though.
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
