The Blower motor on the passenger side under the Dash for a 2000 Ford Contour SVT?
I had the Blower Motor replaced about a month ago underwarranty since it was squeaking, and I guess they didn't put it back in correctly because today when I was heading out of a light it fell out of the dash....
When this happened (or even before as it might have been resting on the piece) it seems to have ripped the piece of material which covered it..also when they did the work they only used two of the plastic retaining clips for the material when they should have used like 5 or 6 and one of the two they used was stripped.
So if anyone knows where I can get the plastic retainers and also the piece of felt that I need...or if these parts would be covered under my warranty since the factory did the work and F-ed it up....then that would be great.
Only bad thing is that I went in there and put the blower back up in its spot correctly (you just fit it in and turn it till it locks) so I wonder if they think I was messing with it?
Thanks Koons in VA.......
also I am new to Mass near Worchester, so if anyone has any good recomendations for a service center it would be apprecaited, thanks.
