#18178 05/31/02 11:45 AM
Z
Zee Offline OP
Z
On a '95 Contour (2.0L) where are suitable points (centrally located) for using a floor jack to lift either the entire front or rear for placing jack stands.
My Haynes manual only shows jack points on the rocker areas.
'95 GL, 108K, stock
(newly acquired & totally unfamiliar)
#18179 05/31/02 12:20 PM
Click here to see the Contour jack points.
1996 Contour SE Sedan 4D (Royal Blue)
Duratec V6 2.5L 24-valve DOHC
Automatic
75,000 miles
No Mods (unless you call the DMD a mod)
Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
#18180 05/31/02 06:07 PM
that link really only shows the same as the haynes...somewhere on here it is said to use basically the same jack point but use a piece of wood between the jack and the subframe....
im a dope so i could be mistaken :p
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
