Posts: 22 |
Well, I would like to paint the headlights black, however it seems that the plastic cover has been "welded" to the headlight bezel. How is it removed? Is it cut?
Thanks
Administrator
Administrator
Posts: 5,037 |
There is a cured white adhesive holding the halves together. That adhesive cannot be melted or desolved away. You have to actually grind a lip off the housing all the way around the seam. Then, you CAREFULLY and slowly pry the lens away from the base. When I did my first set (my own lights) I went into the project expecting to totally ruin them. It just turned out that I did them right the first time.
-Chris
Posts: 1,187 |
what did u use to re-attach the lenses chris?
-Speed Demon- Matt Black 2000 Contour SE Sport (duratec/atx)got body mods? all show, better than stock go  "I might be crazy, but I'm not stupid" speddmn.com
Administrator
Administrator
Posts: 5,037 |
Originally posted by Speed Demon: what did u use to re-attach the lenses chris? Heavy duty, all weather black silicone. One initial bead for the first seal, then an additional bead to fill in the space left by cutting out the plastic ridge.
Posts: 22 |
What tool did you use to cut the cover?
Administrator
Administrator
Posts: 5,037 |
Originally posted by Imabelgianpimp: What tool did you use to cut the cover? Dremel Tool MultiPro with fiber disk.
Posts: 1,218 |
thanks for the info chris.......... But I'm still abit worried to be cutting my car into peices, I'll let you do the work
Chow 1998 SVT #2263 of 6535 chowsvt@msn.com
Posts: 22 |
Originally posted by Chris Hightower:
Dremel Tool MultiPro with fiber disk. Thanks, I'll give it a try.
Posts: 2,809 |
Originally posted by Chow: thanks for the info chris.......... But I'm still abit worried to be cutting my car into peices, I'll let you do the work hahahah! my thoughts exactly!
Posts: 1,537 |
If you are going to try it yourself, buy a pair of headlamps from a junkyard. This way if you fubar them, you haven't touched your car !
I am thinking of trying this in the spring !!
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
