Anybody have directions on how to mount the SVT Side Skirts on to an SE. Recently got some for Christmas. I have all mounting harware but no directions. Anyone?
98' Black Contour Sport GL Zetec ATX
KKM;No Res;Dynomax Muffler;Custome pedal kit;Custom ATX shifter;A-Pillar Gauge Pod w/Voltmeter,A/F Ratio,Oil Pressure Gauges;Side Markers;Zetec and Limited Edition Emblems;Custom Headlamp & Taillight covers;Tinted windows;Ram Air Induction into KKM;Front Strut Tower Brace;Custom Upper and Lower Mesh grills;885 Fog lamp bulbs;Rear Dome light;Ventshades;Remote Start;Headlamp & Taillamp Strobes;Stereo system
matthewbounds@hotmail.com
Administrator
Administrator
If you already have sideskirts it's just a simple swap. If you don't have sideskirts, it's a little more complicated as you would have to rivet the brackets to the body.
Look under the car at the inside edge of your existing skirt. You'll see some plastic fasteners. Pull those out. Also, you'll need to take out one or two of the fasteners on the bottom of the wheelwell liners. Then, they just slide off. Reverse the process to put the SVT one's back on.
Since you will probably have some leftover mounting hardware like the brackets and rivets in the white envelope that came with the skirts, I could use a set. One set got lost during shipping. Let me know, and good luck with your new skirts!
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
Master P
Master P
Thanks for the help. It just seems like there is alot of hardware for this install. I will make it work.
