Page 3 of 3 1 2 3
Kai Offline
Do we know how the stick is connected? In other words, would it be possible to simply make short one (yes, the threading would be a major pain) and replace the big one? confused How do you get down there to see, anyway? Does the plastic around it just pop off?
Kendall
'97 GL Zetec ATX
" Nippy "
Don't quote me on this...
Undo the allan head screw and pull up the knob slightly (not too far or the wires will snap).
Pull the plastic surround at the base off and disconnect the OD wire.
Remove the handle...
This is how Neco describes it...
Kharma is very real and she is one mean b!tch.
Kai Offline
Thanks. Sounds kind of risky. Might have to save that for a day when I'm feeling both bored AND brave! wink
Kendall
'97 GL Zetec ATX
" Nippy "
N
N
It is real easy: I cut mine about 2in. off, and rotated clock ways about 1/4in., If you do this mod make sure you make a slot on the top to make the handle stay in one place.
Later Nick
99 tour se zetec
complete painted interior, BN white gauges,
4.5in. fab. aluim. cold air in take, no res, ported man. hooker header areo chamber muffler, 9mm Ford Racing wires, and bla bla bla more stuff,
painted rear ref., mesh top and bottom, L.E.D w/direction turn signal, trible flames down both sides, L.E.D. washer fluid lights, AND Alot More
Locozetecse
Same color too! T-Red with Greystone interior. Hey I was thinking about painting my dash like yours and I was wondering how you did it. Someone keyed my car and so I bought a bunch of T-Red touch up paint and I remebered seeing a powder blue S-10 with his dash painted the color as his car like you did. The trim looks textured to me so do I need to sand it down first or what? Your car looks nice like that so I definately want to do it now!
1989 Plymouth Sundance 2.5L:
Comp Cams Camshaft, Overbored TB, Ported Intake and Exhuast Manifolds, Mopar Performance 20% Bigger Fuel Injector, Mopar Performance Computer, Mopar Performance Modified Distributor.
2000 Zetec ATX
Gutted Airbox
Removed door ding thingamagigys
Replaced Stock Exhuast (for now), IAT Mod, Future reciepient of HMS Stage II Turbo someday.
2001 Electric Green Mustang V6 AODE
Stock for now, really big plans soon!!!
Faster than a speeding Diahatsu!
Well the dash you just need to clean very well and let dry very well. I used dishsoap to get off all the grease. I do recommend sanding(just a little) the other interior pieces that have a texture and clean them well also. Paint a few coats let dry and spray some clearcoat (a few coats) and let dry completely. Hope this helps and thanks for the compliments. I just don't want no twins. laugh
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
Page 3 of 3 1 2 3
