Posts: 1,181 |
First off, i used search and found multiple (mostly vague and unconfirmed solutions) to stripping the wax without doing harm to the paint. The two that were suggested the most were using a light dish detergent (Dawn, Joy, etc) or just using hot water. With both...some people agreed that it worked very well and gave a clean finish, but others said both these methods can possibly damage the paint (drying it out, stripping the clear coat, etc). So, what is the "up-to-date" consensus?
98 Merc. Mystique LS
Red Wings and US Soccer 0wn j00!
Posts: 4,585 |
Dawn. When used only so often, it does not damage the paint. It cannot strip the clearcaot as that's just another layer of paint. Use Dawn once, then a clay bar, then start your wax/polish.
Posts: 2,847 |
Originally posted by APT CSVT: Dawn. When used only so often, it does not damage the paint. It cannot strip the clearcaot as that's just another layer of paint. Use Dawn once, then a clay bar, then start your wax/polish. That is the first step in the Zaino line, and if is recommended by them, it won't hurt your car. I do this for my first handwash after the winter season.
Posts: 11 |
Don't worry, you won't strip off your clear coat unless you use something abrasive.
Posts: 3,584 |
This wouldn't be an "offical" detailing post if I didn't check in w/ a Mequiars reset...either use body scrub or cleaner, which is the 1st step in the Mequiars process. Also believe it or not theres another cleaner/wax that I've used with STUNNING results...Zymol  Now it does produce alittle resedue when taking it off, but the Zymol is some good stuff.
Roger R SVT/SHO Society SE MI rep 2000 CSVT #1253 of 2150 silver frost/midnight blue 2-8" dark blue racing stripes Mequiars...simply the best! "...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4" USMondeo@aol.com
Posts: 2,906 |
There is some stuff that painters use that works pretty good. It removes grease and wax. Go to any automotive paint store and ask for Grease and wax remover and they should get you what you need no probs.
Josh Aka Spectra SVT 02 Dark Highland Green F-150 XLT Mods: Gunrack and cowboy boots
