Posts: 1,187 |
the skirts wont, i had my tour sittin next to a cougar just tonight, the tours pretty significantly longer in both wheel distance and overall length iirc
however that air dam is QUITE bad-ass wonder if that'd work..
edit:: just took a 2nd look at that pic, it doesnt look like the skirt goes end to end maybe it would work? Mr hightower all mighty master of mods, enlighten us!
-Speed Demon- Matt Black 2000 Contour SE Sport (duratec/atx)got body mods? all show, better than stock go  "I might be crazy, but I'm not stupid" speddmn.com
Posts: 10 |
Just to let you guys know. The Visteon side skirts for the Cougar do not go all the way back. They stop about 3/4 of the way back, so I would have to assume they would mount fine on a Contour.  The air dam on the other hand is fitted to the exact curvature of the Cougars front end, so it will not fit.
Mark 2000, V6, ATX, Spruce Green, Razzi GFX, Borbet Type S Rims, Potenza RE-730's, Chrome Mesh Grill, Smoked Side Markers, Tinted Windows, Aluminum Racing Pedals, Ram-Air Intake Hose, K&N, Cougar Emblem Switch, Minilight Mod, UltraWhite Headlights and 100w fogs. http://sprucecoug.freehomepage.com/
Posts: 244 |
You want a kick butt scoop you should check the custom job Cam2 did. Check the "Ram Air Scoop" in the General forum.
Scott 96 SE, MTX, BAT 22mm rear anti-sway bar, BAT springs and Spax struts 96 Caprice, 9C1 Rayon is made of wood!!!
