Posts: 422 |
fit and look good? It is from a Cougar. Would be using it right now for looks. Later I would move it to making it functional. [img]http://http://www.newcougar.org/discounts/visteon.html[/img]
98' Black Contour Sport GL Zetec ATX KKM;No Res;Dynomax Muffler;Custome pedal kit;Custom ATX shifter;A-Pillar Gauge Pod w/Voltmeter,A/F Ratio,Oil Pressure Gauges;Side Markers;Zetec and Limited Edition Emblems;Custom Headlamp & Taillight covers;Tinted windows;Ram Air Induction into KKM;Front Strut Tower Brace;Custom Upper and Lower Mesh grills;885 Fog lamp bulbs;Rear Dome light;Ventshades;Remote Start;Headlamp & Taillamp Strobes;Stereo system
matthewbounds@hotmail.com
Posts: 422 |
Sorry I fixed the link..... Hood Scoop
Posts: 422 |
Still broke! Try this: HoodScoop
Posts: 248 |
I would have to say just as my own personal opinion.... I wouldnt do it. If I drill holes or bondo something to my car, it is going to have to function as well as look good. If you mount the scoop in the center, it may look ok, but the only function it will have is to shave a few degrees off the intake manifold temp. For you to notice any real performance increase, the scoop would have to be mounted on the side to push air into an open air filtration system, which would function well but would probably make the car look unbalanced..... unless you went with one scoop on each side. But it is your car... if you think it would look good, then go with it.... this is just my .02 cents worth.
Administrator
Administrator
Posts: 5,037 |
I bet you could get that scoop for MUCH less than $185 from Bill Jenkins.
Posts: 422 |
But it is from Visteon not Ford.
Posts: 8 |
But it is from Visteon not Ford. Same thing isn't it? Just their parts division. Did they break free yet?
Posts: 355 |
that visteon looks real nice on cougars, might work on contours. Look around before you buy, you can get them from ppl for less than 185!
Posts: 422 |
Checking for sale ads now. Anybody have Bill Jenkins email address?
Posts: 743 |
think those side skirts would work on a contour? if this is a stupid question...i dont know the cougar dimensions so :p
