Posts: 68 |
Chris,
That looks awesome. I want to try the same thing...if you have time could you do a walkthrough for how to attach the pieces to your car... I'm can't imagine how the rear oval is removed in the first place...
1998 Black SVT Window tint 27% KKM True Rev Sport Induction Kit
Posts: 1,681 |
the rear oval can be removed with some fishing line and a pair of gloves. you just get the line in back of the badge and very slowly move the line back and forth. you need the gloves to protect your hands from getting cut by the line. the badge is held on with a foam which is sticky on both sides, but is easy to remove. then get some wd-40 to remove the left over sticky suff from your paint.
Posts: 11 |
chris I just tried to do that and when i sanded the blue off it scratched the clear oval and the paint job looks like ****! what kind of paint did you use and how did you keep from scratching the plastic?
Administrator
Administrator
Posts: 5,037 |
Originally posted by Low Tones: chris I just tried to do that and when i sanded the blue off it scratched the clear oval and the paint job looks like ****! what kind of paint did you use and how did you keep from scratching the plastic? I did scratch the plastic, but I used medium then fine grit. Once it is smoothed, paint over it. Don't worry abou the chrome lettering unless it comes off with the emblem during removal.
Posts: 2,683 |
I Just did mine about an hour ago,looks GREAT!!!!!!
Howard 1998 Silverfrost SVT #1612 June mods: 17" ADR RS Limited Limix Wheels with 215/45/17 Yokohama AVS Sports
Posts: 567 |
If anyone wants a little euro flair for their badge... http://www.essexracing.co.uk/Ford_cfb.htm
CURRENT RIDE: 95 GL FORMER RIDE: 99 SVT ( www.mysvt.com) "You only live once, but if you lived my life, once would be enough." -Frank Sinatra
Posts: 2,683 |
HA,that one that says cabriolet,I thought for a second it said CHEVROLET,and I was going to order it!Maybe I could get better service at there service dept! :rolleyes:
Posts: 56 |
Attn: Chris Hightower
What did you pry the logo off with? I don't want to get out there and break the damn thing. I can probably get it off with no trouble, but thought I would ask.
thanks
'98 SE Sport Fog light mod and sidemarkers No significant power mod
Posts: 983 |
no need to pry.. remove the grill. on the back are two (i don't know what you call it) holding it. use a wrench and get them off.. very easy.
1998 Vibrant White 2.0 Zetec / "Powered By Ford" Shoulder Pads / 3A Racing Pedal Covers / Pre-98 Sail Panels / Alpine SPS-5729 in the front / JL Audio TR570-CX in the Rear / Zetec Inside Sticker / Replica Porsche 944 Rims (5 circle ones) / CEG Sticker / Super White 9006 Low Beams / Euro Style Short Antenna / Broadway Wide-Angle Mirror / Painted Front Grill Vibrant White / CTA Intake / Accel Ignition Coil / Diablosport Chip / Dynomax Super Turbo Muffler / Ractive Amber Side Markers / ST200 Struts / Eibach Springs
Posts: 1,225 |
I had trouble getting the rear ford emblem off, kinda chipped it so I stopped before I did more damage...how did you get it off Chris???
Ryan
Latest Mod: Mirko Splitter
