You need to "encourage" it out of its location. Those boxes in the end make it harder but all you need to do is watch out where the hoses are on the passenger side, you may want to gently move them higher and around the backside of the black boxes on the end and gently force it from its location.
the clips are reusable as long as you did not break them taking them off! Clean and Prime the surface first with non-metallic or plastic primer or else the paint might/will chip/flake off eventually.
Hope this helps...took me a while to figure it out too...just keep at it and it will come.
Originally posted by S.V.T. Contour Lover:
what about those little panels on the sides. I have unscrewed all the screws but there is one on each side where I can't reach jand it seems that I can't get it out without unscrewing thoses little panels. I will go and try to wiggle it out w/o unscrewing those last two screws on each side. Thanks dude!
