Posts: 111 |
i just want to know.. if i had 4 blue LED's, and connect them to the headlight switch. how would i do so? would i just connect the LED's in series and connect them to the headlight switch? or would i need to connect them to a resistor. honestly.. i have no clue
sorry for the dumb q
basically i just want to light up 4 blue LED's.. how would i do so?
thx
Posts: 4,585 |
Connect in series with each other. They probably don't matter which gets + or -, just connect one lead to one side, then chain together, then last lead from last bulb to ground.
Posts: 753 |
i thought you were asking about porn for a sec, lol
No car anymore ;\ (taking a break from driving due to several misfortunate occurances) Newest mod for my Dad's Cobra 'vert: My beautiful girlfriend and I for passengers when we want to go somewhere
Posts: 111 |
thanx a lot man
but i what i dont get is, wont the bulbs blow if the current is not controlled?
Administrator
Administrator
Posts: 5,037 |
It depends on the voltage rating of the LED's. If they can handle 3V a piece, you can run them in series. And, YES it does matter which side is anode and which is cathode. they all need to be facing the same way. -|>|- -|>|- -|>|- -|>|-
If one is switched, no voltage will pass through them.
If the LED's aren't rated for 3V or more, you will pop them.
Posts: 9,178 |
Originally posted by zetec inside: i thought you were asking about porn for a sec, lol At least I am not the only one that had that thought cross their mind!
Posts: 111 |
Originally posted by Chris Hightower: It depends on the voltage rating of the LED's. If they can handle 3V a piece, you can run them in series. And, YES it does matter which side is anode and which is cathode. they all need to be facing the same way. [b] -|>|- -|>|- -|>|- -|>|-
If the LED's aren't rated for 3V or more, you will pop them.[/b] what would you do if they werent rated 3V each?.. or if they were.. say you only wanted to run 2, that would be 6V total.. so then what would you do?
Posts: 165 |
I'm pretty sure you can wire in a resistor to bring the voltage down.
Mike Silver '99 SE V6 MTX, Eibach, Koni, Res removed, Dynamax B&M, Boston Acoustics, Fosgate, JL, ST200 wheels
Posts: 888 |
you should add a resistor anyways. for current reasons.
