dankboY Offline OP
any ideas on this?i see there are a couple plastic "plugs"??
i also got the hole where the stock antenna was filled and painted...cost me $275...ill post some pictures as soon as i get my digicam back smile
1999 Contour SE comfort package zeeeetec VCT, that light blue colour
Mods:
*Sony Mobile ES Deck, MTX Subs, Precision Power Amp, Boss tweeets
*Mondeo Antenna Mod, stock antenna hole filled and shaved
*Tinted glass
*Lower bumper grille custom (wow took me nearly all afternoon)
*KKM intake, platinum plugs, full Mobil-1 Synthetic oil conversion
*zetec badging
Future:
*Clear corners/blue turn signal lamps (when i get the testicular fortitude)
*exhaust/rims (when i get the money)
*sidemarkers/remove door dings (when it gets warm outside again)
N
N
I got this done some time back, the guys who painted my attenta part did the two holes for the plate holder, it looks easy 2 do with regular body fill and a good detail. laugh
SVT EMBLEM MOD HERE
:::96:C:LX:::
Black 2.5L ATX "my beater" - Shaved ? badgeless ? SE rocker panels
:::99:SVT:C::: #2566 of 2760
T-RED/TAN "the bitçh" Brullen Cat-back w/ 3.5" angle-cut tips ? BAT European Suspension ? AFE Filter ? CnL 73mm MAF ? Diablosport Chip :MNQ3: ? Mirko front spilter ? Apexi SAFC (i'm scared to install! anyone in Norcal wanna help me?)
..::nyceboicreations.com::..
email:junkmail@nyceboicreations.com
Just pry off the plugs, the holder will come right off. You might want to reach under the bumper(if possible) to pull out whatever parts were on the inside. I didn't, because I forgot. I had to take my holder off because someone cracked it up in a parking lot.
1999 Silver Frost SVT
#609 of 2760
Born on 12/3/98
KKM Intake
Removed Resonator
35% Window Tint all around
Tinted Tail Lights
ElKy Mesh Grilles
HID
Dyno'ed at 175.3HP/155.5TQ
It's not fun but the correct way to do this is to take the bumper cover off and cut the plastic rivets from the inside. This process however takes too long. I would suggest cutting the long center piece of the rivet off & drill out the center. You can get plugs to fill the holes although to fill them in with a plastic repair bonding agent looks better. This however becomes expensive do to the fact the bonding agent is itself expensive & hard to find, not to mention the bumper cover will need to be painted again. these bonding agents can be found in a paint supply store. Such companies as Lord Fuzzor & 3M are probably the most widely used.
Credentials:
ASE Certified
I-CAR Certified
With experiance in auto body & frame repair, automotive refinishing as well as metal bonding, plastic bonding & welding
My Car:
'93 Probe GT with NO modifications.
"Now you see why I ask alot of questions."
I'm just rollin the dice hoping I don't have to install mine. There's a bill they are trying to push right now that would eliminate the requirement of a front license plate. I figure its worth taking the chance. It's a $80 ticket but I really don't feel like puttin' holes in my bumper.
'01 Cobra Laser Red
