#130512 04/25/01 07:40 AM
Remember the older tours, they had the green light in the door handle hole. Can you do that to 99's??? What would you need???? Probably stoopid, but I lika aloo
#130513 04/25/01 06:33 PM
Someone stated they used LED's in there. I would assume you could you the 12v source for the lights in the switches on the door panels...and the LED's won't burn out like the original ones.
I reserved doing this on a rainy day...I just seem to have 300 rainy day projects in front of it.
Joey
2000 SVT Black
#1811 of 2150
MODERATOR
www.svtperformance.com
If you're in a war, instead of throwing a hand grenade at the enemy, throw one of those small pumpkins. Maybe it'll make everyone think how stupid war is, and while they are thinking, you can throw a real grenade at them.
Joey
2000 SVT Black
#1811 of 2150
Dad always thought laughter was the best medicine, which I guess is why several of us died of tuberculosis.
#130514 04/25/01 07:50 PM
-Steve
'99 T-Red SVT #102
sholland@svtperformance.com
Search?
#130515 04/26/01 11:25 PM
4
4
That link isn't the door handle light installation instructions. Its instructions for installing the door courtesy lights on the bottom of the door of a Mystique.
'98.5 Mystique GS ATX/re-contented door lights/K&N Filter/Energy Suspension Sway Bar Bushings/Mintex Street Pads/high-beam bulbs in low-beams/Pioneer DEH-P3100 receiver/Pioneer TS-A6855's in all doors/removed ding gaurds
Justin
'02 Ranger Edge ext cab
Retired: 98.5 Mystique
#130516 04/28/01 06:56 AM
Once you get the light wired you'll have to modify the cup of the pull handle a little. The earlier tours had a clear square piece in front of the light to spread the beam evenly. You could probably just cut a small hole through the top of the pull handle cup and mount the light.
Brad Wilson
1998 Silver Frost SE
brantleyiii@earthlink.net
Photopoint Album-(Updated 4/20/01)
