Posts: 306 |
I have an opportunity to have my grill painted black. I decided I would only do it if I could get the crome on the 98+ tours trunk lid painted as well. Does anyone know how to remove just the crome so that it is separated from the red reflective plastic? I'm afraid it might be glued on and if so will probably break when I try to pull it off. Also..how do you think it will look with blacked grill/trunk...with light blue body.
------------------ 98 Contour GL V6
Current Mods: Mud Flaps
98 Contour GL V6
Posts: 2,906 |
I am not sure how it is attached but if it is glue you can use a heat gun or blow dryer to soften the glue. Then you won't break it. Hope this helps. ------------------ Black E0 SVT #2239 K & N Induction Josh's SVT
Josh Aka Spectra SVT 02 Dark Highland Green F-150 XLT Mods: Gunrack and cowboy boots
Posts: 1,108 |
DON'T TRY TO PEEL IT OFF I tried to & I broke It.Luckily my Mom was leasing a contour and I just switched rear pannels.Ford didn't even notice.It looks like s**t without the chrome strip ------------------ Kool Aid(JEFF) NY98 Svt EO Toreador Red #43 17inch DTM White Konis Struts,Eibach Springs,Bassani exhaust Kkm Filter Custom Stero Painted Grill Red Calipers Clear Headlights,A6 marker's, Auto meter pod Voltmeter and Air/Fuel Gauge B&M Short Shift.Braided Brake lines too Install svt41574@aol.com [This message has been edited by kool aid (edited February 05, 2001).]
Kick Ass don't Kiss It
Posts: 233 |
thanks for the word of advice koolaid !!!!!!!!!!!!  I was thinking of it too,,, wow that would of sucked if I broke it off
2000 Contour SVT #1000 0f 2150 Built on 12-17-99, In Kansas City Custom Painted, "LOOK DEEP THE DIFFERENCE IS WITHIN" -Custom dual pod- indiglo gauges- no res.-KKM intake- Bad A!! NEW Alpine Head Unit-tinted windows- rain visors-the good stuff still to come- !!!!
Posts: 1,507 |
Just have the guy who is painting it tape it off. I removed the whole reflector/plate assembly and left it at the shop when I had my grilles and chrome ring on the front painted. [img] http://albums.photopoint.com/j/View?u=1189319&a=8760449&p=34422234[/img] ------------------ -- Mike -- Bel Air, Maryland Black 98.5 SVT #5486 w/ a few mods moesvt@yahoo.com
-- Mike (Moe)Lester -- 98.5 SVT #5486 moesvt@comcast.netGet your a$$ on IM and stop wasting bandwidth!!!!!!
Posts: 306 |
Thanks for the warning guys..I won't even try to peel it off. I don't even want to know how much it would cost to replace that crome strip. I have nightmares about those headlights ever getting cracked by a rock.I can't wait until the day when there are lots of tours in the junk yards. Probably won't happen for another 10 years though. That way if I want to experiment I won't have to spend the big $$$.
98 Contour GL V6
Posts: 1,108 |
I'm suprised ford didn't paint It black from the factory for the SVT's or the sport versions.I also see on 95-97 contours the SE has a chrome strip In the bumper.I thought these are the sport versions.Chrome to me should belong on the luxury models.
Posts: 413 |
In re: to above posting: ALL 95's (SE, GL, LX) had the chrome strip NO 96-97's (SE, GL, LX) had the chrome strip
Any deviation would be just that.
HTH DAvid
