Anonymous
Unregistered
Anonymous
Unregistered
Just curious if any of the stock wheels from other FoMoCo products would fit on the Contour? For example, the 16" off a late model Thunderbird, or SHO, Mustang wheels (minus the pony caps), etc? Contours are a bit hard to find at the friendly-neighborhood junkyard  Thanks. ------------------ Andres '96 Contour GL Zetec, ATX, ~68K
Posts: 610 |
our bolt pattern is 4x108 the only other fords with the same are the "stylish" tempo and the "wonderful" focus why dont you find aftermarker rims
------------------ 2000 se tropic green kkm intake, svt exhaust (thanks antonio-capitol), fog light mod (thanks chris a.-jersey), pioneer 4100 (no remote-your welcome chris), green interior lights (dome light is crappy), mesh grill(still lookin for a svt grill) 1999 se steel blue email-jessneric@peoplepc.com yahoo instant messanger-eric_j_linders icq-94866821
capitol ceg/southern maryland 2000 se tropic green kkn intake(will replace with svt soon), green interion lights(replacing with neons), pioneer 4100-no remote, fog light mod, svt exhaust, side markers, badgeless, 9005 instead of 9006(headlights will be replaced soon, pioneer 6x8 3 way(front) and 2 way(rear) need to istall-obx pedels 1999 se steel blue blue headlights and fog lights need to install sony cd headunit email-jessneric@peoplepc.com yahoo im-eric_j_linders aol im-ericsgreen00 msn im-ericsgreen00@altavista.com
Posts: 3,584 |
The problem with use of the T-Bird and the Stang is that those cars are RWD, not FWD and therefore the wheels would stick out and make your Tour look like an old roller skate! I really like the wheels on the Focus ZX3 and ZTS, check those out. If you wanna see what your car looks like w/ other wheels try here www.tirerack.com go to buy wheels and follow the directions, you'll see your ride and then GO! Roger R 2000 Contour SVT #1253 of 2150
Roger R SVT/SHO Society SE MI rep 2000 CSVT #1253 of 2150 silver frost/midnight blue 2-8" dark blue racing stripes Mequiars...simply the best! "...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4" USMondeo@aol.com
Posts: 5,296 |
Not only that, the Stangs have 5 bolts and Tours only have 4. Originally posted by Roger R: The problem with use of the T-Bird and the Stang is that those cars are RWD, not FWD and therefore the wheels would stick out and make your Tour look like an old roller skate! I really like the wheels on the Focus ZX3 and ZTS, check those out. If you wanna see what your car looks like w/ other wheels try here www.tirerack.com go to buy wheels and follow the directions, you'll see your ride and then GO!
Roger R 2000 Contour SVT #1253 of 2150------------------ \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ AirKnight (Dominic Ho) Buffalo, NY
AIM: AirKnight on MTBMy Contique  \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
Posts: 413 |
"Fox" bodied Mustangs (and Capris) are 4 lug. Believe the "Fox" body style run was 82-93, but don't quote. Exception would be the 84-5-6 SVO Mustang, which was 5 lug.
Posts: 618 |
I believe the new Cougar wheels will fit!
GOD BLESS AMERICA!!!
Ted tdavidk76@hotmail.com '95 SE • DOB-4/20/95 • every option • Champagne • Duratec • MTX. Mods: Taylor wires • Bosch +4 • Eibach/Sachs Super Gas (half done) • rear BAT urethane bushings • SVT air box (thanx Dom!) • fogs w/parks • 885 50w fog bulbs • Ray's THF • rear dome • lighted moonroof switch(thanx again Dom!) • tranny cocktail • minor stereo mods. Yet to install: Front Eibach/Sachs • Front BAT urethane swaybar bushings.
Posts: 38 |
Yes, cougar wheels from the new gen will fit, I have pics of Marks on a MKI tour, and mine on a MKII tour Tony
------------------ AntMowery@worldnet.att.net 98 SE V6 MTX SVT KKM intake, Pro Flow 75mm, No Resonate, VooDoo Knob, Fog Fix Headlight fix, 16 in Cougar wheels, SMA strut towers bars, SVT exhaust SMA straight intake, B+M edge, Bosch +4 86 MR2
Posts: 586 |
i heard with the new cougar wheels, there is some rubbing, how major?
price for rims with tires...i think they look bad azz on the tour...n e one?
------------------ 96 contour gl "zetec inside" numerous mods
1996 Contour GL
