does anyones car ding when you open the door or do i have some kind of problem?
  • 98 Svt Toudor red/ Silver(Two tone)
    Midnight Blue and Black Carbon fibre Kit
  • SCA Cold Air Intake
  • Poly Engine Mount Inserts
  • Bosch Plat +4 Plugs
  • 8.5mm Magnacore Wires
  • 80/100 Watt Light conv.
  • Alpine 7864 SE Silver Head unit
  • Alpine GEQ 320 Digital Crossover linked to head unit via AI-Net
  • Phenix Gold M44 amp for highs and mids.
  • PPI PS2100 for JL12W6 flush mounted in rear spare tire hold.
  • Eclipse Componets all around.
  • Unorthodox Stage 1 Clutch
  • Fananzia Flywheel @ 8 lbs
Anonymous
Unregistered
Anonymous
Unregistered
Mine goes ding !
It's pretty annoying sometimes , but I guess it has it's merits . As far as I know , they all should have it .
"If you want to finish first ... first you must finish !!!"
Teal blue '95 SE V-6 ~ KKM Tru-rev (yee-ha!!) ~ Bosch Platinum plugs ~ SVT exhaust ~ TH fix ~ Badgeless ~ Audi A-6 side repeaters ~ Factory style DRL mod ~ Front end bra ~ Ford Motorsport mudflaps ~
Mine dings in my 98.5
Tim
Administrator
Administrator
I think they all ding, its just if you open the door and have left your keys in the ignition or you have left your lights on. It'll keep you from coming back to a dead battery or keys locked in the car.
It's all about balance.
bcphillips@peoplepc.com
the ding comes from the lock-tumbler not fully "popping" out when you remove your keys... i read this from someone on this board about 6 months ago because I had the same question
SO... when you get out of your car next time and take the keys out and you still hear the "ding, ding, ding" and your lights are off, just push on the ignition tumbler (where you put the ignition key) and it should pop back out and the "DING" goes away
'98 SilverFrost SVT
#1037 of 6535 built
Toadster's SVT Roundup
MODS: KKM Intake, TH-Fix, Synthetic Oil, 18% tint all-around, TBD....
Todd Christ SVT Contour Registry
MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator
'98 E0 SVT Contour #1037 of 6535
ok well mine has no ding at all so if any one knows where that comes from that would be great! so i can fix it
ok look on the car and find the button that the door pushes. its a lil black nub. push it in and out a few times.. wiggle it around. thats how i fixed mine. Ding, ding ding ding
matt
1998 Black SVT Contour.
No Mods yet.
~Matt
well the ding dosnt even come on when i leave my lights on
Took mine out.Know i can leave the door open with the radio on while cleaning.Just don't leave the headlights on by mistake or the keys in the car
Kool Aid (Jeff)
98 Svt EO Toreador Red #43
17inch DTM White
Konis Struts,Eibach Springs
Kkm Filter
Custom Stero
Painted Grill Red Calipers
Clear Headlights,No Resonator
Auto meter pod
Voltmeter and Air/Fuel Gauge
B&M Short Shift.Braided Brake lines too install svt41574@aol.com
Kick Ass don't Kiss It
Mine dings. You may have a faulty chime unit.
P. Valdez
Las Cruces, NM
1999 navy blue SE
Zetec ATX
PIAA 9006/H3 bulbs
Philips Premium 9005 bulbs
Hella Optilux 1100 foglamps
Sidemarkers
DRL Relay
Maxxis UA603 205/60HR15 tires
KKM on the way!
P. Valdez
1998 VW Jetta TDI
1.9L I4 direct injection turbo diesel
5 speed manual
no mods, no money
AIM:PackRatTDI
My exhaust smells better than yours.
