#124412 10/26/00 08:41 PM
I'm thinking of removing the cupling from over the low beam bulb in my 98.5 SVT. Anyone out there done this? or have any ideas as to what they may do or problems this may cause?
-Nate
Eibachs
Touring Wing
Tint
Sony Head Unit
Amp and 2 MTX 12's
Misc.. http://home.adelphia.net/~nbottorf
#124413 10/27/00 12:49 PM
Can't recommend it! That cover is what takes all the light from the bulb and directs it to the parabolic reflector at the back of the bulb to properly direct the light. Takin out the "cap" will cause the light to be spread all over the place and you will lose intensity and density. Plus, I think you have to crack open the housings to get it out. At your own risk.
98 Mystique V6 5spd.
Modified airbox
Cool Blue bulbs
CD and other stuff to come!
Eric B.
Ottawa, ON, Canada
98 Mystique V6 5spd. Toreador Red
Modified Airbox with K&N drop-in, Cool Blue bulbs, Homemade solid brass shifter knob, Sony CDX-L300 head unit
http://photos.yahoo.com/LBuzzer/
#124414 10/27/00 01:57 PM
I'm sure I'll have to open them up.. but as for reflecting... I'm going off the high beam concept... which has no cover..
#124415 10/27/00 08:57 PM
N
NMC Offline
N
The 'cover' as you call it acts to block any light other than reflected light so the beam is straight out from the headlamp. This makes for better lighting in poor weather conditions, exactly like a fog light. The high beam doesn't have one cause all you want them to do is shine as far and brightly as possible. You don't use highs in bad weather now do you? Removing the cover will actually give you brighter lighting in clear weather, but more dispersion in fog and rain. The choice is yours.
96LX/ATX/A4 repeaters/SVT exhaust/KKM/E1 suspension/SE rockers/BAT swaybar/urethane bushings/Kenwood 7 speaker syst./
Soon: SVT brakes/E0 rims/225 50 16 XGTV4's........
96LX/24V/ATX/Midnight Red/A4 repeaters/SVT exhaust/KKM/65mm throttlebody/SVTsprings and ST200 struts/SE rockers and BAT spoiler/BAT 19mm swaybar/urethane bushings/Kenwood 7 speaker syst./E1 SVT brakes w Powerslot rotors/9005 lowbeams/885 fogs/50% tint/Michelin XM+S 130's for winter/E1's with gForces for summer...and now "New Paint!!"
87 Renault GTA convertible/2.0l/mtx/Sony sound/otherwise stock
http://members.shaw.ca/neilmc/
