Page 2 of 2 1 2
Going to Radio Shack, but first,what is the difference between 1 x 30 Ohm /20 Watt (Louis W.)and 2 x 10 Ohm /10 Watt (Blake N.) resistors?
Thanks,
Mark
If you hook two 10-ohm resistors in series, you get a total resistance of 20-ohms. This means that the sidemarkers are going to be a little bit brighter than if you used a 30-ohm resistor.
Louis Wang
Austin/Sugar Land, TX
1998 Black E0 #3826
http://web.wtez.net/tw57472
-Louis
1998 Black E0 #3826, lightly modded
So I hit Radio Shack on my way home and had no problem with the resistors (P/N 271-132, $.99), but I had 3 rectifiers to choose from; all are 3 amp, but have 50PIV, 200PIV, 400PIV. What is PIV, and which should I use for this mod?
Thanks,
Mark
PIV = peak inverse voltage. Basically the maximum voltage the diode can 'block' before it breaks down. Since our cars are 12V systems, 50V is more than enough.
Louis Wang
1998 Black E0 #3826
-Louis
F
F
just installed by a6 marker lights and they look great. i did not have to break off the tab on the lens housing as stated in the how to section. i cut the hole the same as the hole in the fender of a a6 and no two way tape was needed. i would like the bulb to be a bit brighter when on with the park lights. can anyone help me with the proper resistor required?
my son is named ford!
95se,kkm,dual flowmasters,no rez
If you want it brighter try a smaller value resistor. The wiring diagram shows a 20 ohm resistor. They are a couple cents each, so it should cost too much to find something you like.
Louis Wang
1998 Black E0 #3826
Monster Flow, ASP pulley, hi-flow resonator
A6 side markers, shift light, SRP pedals, SVT TachGlow
and more!!
-Louis
Huge thanks to jjh for posting Blake Nelson's diagram, and to Louis Wang for the electrical education! I finished the side marker project and it looks awesome! I used Mondeo lights from BAT. My car is silver, and the contrast really pops with the amber lights. I failed to get the digital camera from work for in progress pics, but i'll take some finished and post. I bought small 'project boxes' from Radio Shack to house the resistors and diodes - very clean looking..........
Page 2 of 2 1 2
