I have a 97 with aluminum rims. I have tried everything left and right for getting brake dust off. I used eagle wheel spray and hose,also ammorall spray and hose too. Both leave my rims looking streaky or hazey? If you can follow what I mean. White haze's that look like water that ran?
After I do spray these cleaners on I go to work on the rim with a sponge or brush seeing how none of them get all of the gunk off the rim!!
What types of wheel cleaners do any of you guys use?? I even tried simple green and it too left them hazey as well?
They seem to be clear coated so to get the haze off I use windex and it works like magic. The only bad thing about the windex on coated rims is when the "NEW" brake dust sticks to the rim it sticks around where you wiped!! like a magnet. SO you can see your wipe marks if you mised anywhere!!!
Any aluminum rim ideas would be appreiated guys!!
Thanks
Spankey
