Posts: 159 |
Just one more question regarding the side marker install.
Is the Audi wiring harness (green and brown wires) absolutely necessary? If so what is the P/N? I called my local Audi dealer and he quoted me the same prices for the P/Ns listed in the HOWTO, but wanted $97 for the L wiring harness and $75 for the R side!! If he was pricing the right P/Ns for what I need then I think I'll do the wiring myself.
So do I really need the Audi wiring harness?
------------------ Ed 2000 SE Sport MTX
Mods: Knauberized doors and badges / Mobil 1 oil / Mobil 1 ATF and FM / Fog Light rewire / THF
Future plans: Glasspack and SVT exhaust / E1 wheels & tires / springs and struts...
Ed 2000 SE Sport MTX T-Red & Loaded
'95 Chevy Caprice 9C1 Rear wheel drive and V8!
Posts: 681 |
well, the wiring harness would be hard to do without only because it plugs directly into the sidemarker socket. old A6 sidemarker sockets just had a simple spade terminal connection, but later ones actually have a plug-&-socket kinda deal. however, those prices are WAAAAAAYYYYY outta line. i paid about $16 each for mine from http://www.donmcgill.com in houston, TX. TOTAL cost to my door was about $60 incl. shipping. ------------------ blake 98.5 E1 SVT #4910, silver frost - KKM, SHOshop pulleys, borla exhaust, ES MMI, taylor wires/bosch plat +4's - 35% tint, momo shift knob, A6 sidemarkers, some audio improvements, 'advanced method' fog light fix - yakima roof rack
blake 02 acura RSX type S, arctic blue pearl/ebony - OEM fogs, S2k shift knob, 35% formula one tint, injen SRI 62 chevy C10 fleetside pickup, tan - stock I-6, 3-on-the-tree, currently immobile in my garage former owner of: 98.5 E1 SVT #4910, silver frost
Posts: 2,112 |
I went without and soldered the wire directly to the copper spades on the socket. It separates from the reflector assembly so the only advantage with the harness is that it's easier to attach wires. If they've revised the sockets, then I'm not sure. I had them show me a harness and whatever they were asking at the time, I thought it was too much. For $75 or $97 (!!) those harness better be made of gold. ------------------ Louis Wang Sugar Land, TX 1998 Black E0 #3826 http://web.wtez.net/tw57472
Posts: 345 |
All you need in addition to the diodes and power resistors is four .25" Faston terminals, 16 gauge wire, some shrink tubing, a handful of 3M Current Taps and a few tywraps. Make you own harness and save $ome buck$$$. AL
------------------ Red '98 SVT E0 3098/6535 KKM Elizabethan EGR Plate TH fix Bosch +4s B&M with reverse lockout disabled and centering spring removed Mobil 1 oil and trans fluid PowerStops and painted calipers all around A6 Side Markers Horn recontent Painted Sail Panels VooDoo Knob and pedals Blau Houston & CD changer Cup holders that work BAT Sill Plates Sway Bar bushings when I get around to it
Red '98 SVT E0 3098/6535 KKM, Elizabethan EGR Plate, TH fix OMP front brace Hightower rear brace DMD B&M with reverse lockout disabled and centering spring removed Mobil 1 oil and trans fluid A6 Side Markers, Optima orange, Horn recontent Painted Sail Panels VooDoo Knob and pedals, RogerR deadpedal Blau Houston & CD changer Cup holders that work Donnelly mirror BAT Sill Plates and a Bullitt fuel door
Posts: 1,207 |
I am planning on doing this mod very soon, and I'm interested in the comments about the new sidemarkers... there's actually a plug now? No longer the simple copper spades?
Has someone used the new version (if it exists) to do this mod? I ask because I was planning on modifying the light to fit through the existing hole without enlarging it. I'm wondering if the more complex plug setup will make it more difficult . I can't imagine it would, as it can only be two connectors in there, but if someone knows first-hand I'd like to hear.
------------------ Eric Walton 2000 Silver Frost SVT 1571 of 2150 Richbrook shift knob Pioneer 6x8 2 & 3-ways Hoodliner removed Energy suspension motor mount inserts and rear bar bushings Lighted SVT Fog lamp mod
Posts: 681 |
Originally posted by bigwalton: Has someone used the new version (if it exists) to do this mod? I ask because I was planning on modifying the light to fit through the existing hole without enlarging it. I'm wondering if the more complex plug setup will make it more difficult . I can't imagine it would, as it can only be two connectors in there, but if someone knows first-hand I'd like to hear.
yep...they do exist...that's what i used. only hard part is that you can't feed the harness through the fender hole, make the connections, then push it back in like you might have been able to w/ the spade type. i loosened the fenderwell liner by removing a couple of the screws near the sidemarker hole and then reached behind it while laying on my back on the ground. it's working somewhat blind, but it's relatively easy to find the end of the harness in the fender and then find the socket to plug it in to. based on the pictures in the FAQ how-to, the sidemarker socket is identical to mine but the wiring harness i got didn't have anything that remotely resembled the spade terminal thing. it just had two wires that disappeared into a round black plastic/rubber plug...it's been a while, and i didn't bother trying to pull it apart, so maybe the spade terminals are just hidden inside. don't think so, but anything's possible... ------------------ blake 98.5 E1 SVT #4910, silver frost - KKM, SHOshop pulleys, borla exhaust, ES MMI, taylor wires/bosch plat +4's - 35% tint, momo shift knob, A6 sidemarkers, some audio improvements, 'advanced method' fog light fix - yakima roof rack
