#123276 09/10/00 05:20 AM
There is a page on this web site that shows the relay position in the engine bay fuse block for the DRL relay. Mine can accept the relay. Where can I buy one? Dealers?
Thanks,
Martin
Martin
99 Silver Frost SVT
#1060 of 2760
New 2000 engine at 25K thanks to Ford
18x7.5 Alba Blaze rims
225/35x18 Bridgestone Potenza S-03 Pole Position tires
EBC Sports brake rotors in front
EBC GreenStuff at all 4 corners
Pioneer DEH-P3000 AM/FM/CD
Pioneer TS-A6813 all around
JC Whitney Diamond Blue 65W low-beams
Sylvania 885 50W fogs
DRLs
#123277 09/10/00 06:01 AM
N
NMC Offline
N
Carefull, they're not cheap. If I pull my relay out my High Beam lamp flashes. Assuming yours doesn't flash all the time, there must be more to it than plugging in a relay.
96LX/24V/ATX/Midnight Red/A4 repeaters/SVT exhaust/KKM/65mm throttlebody/SVTsprings and ST200 struts/SE rockers and BAT spoiler/BAT 19mm swaybar/urethane bushings/Kenwood 7 speaker syst./E1 SVT brakes w Powerslot rotors/9005 lowbeams/885 fogs/50% tint/Michelin XM+S 130's for winter/E1's with gForces for summer...and now "New Paint!!"
87 Renault GTA convertible/2.0l/mtx/Sony sound/otherwise stock
http://members.shaw.ca/neilmc/
#123278 09/10/00 08:42 AM
1
1
Nope, Thats all you have to do is pull out the jumper and insert the relay in it's place. You can get the relay fairly cheap from Bill Jenkins.
parts@sentryautogroup.com
Thats where I bought mine. I got it with several other things and total cost with shipping was around $35.00 Tim
Timothy Kirk sobeit99@yahoo.com
Tulsa, OK
99 SVT Black/Midnight Blue
1876/2760
173.1 HP / 158.7 Torque
Now with heads up display
http://photos.yahoo.com/sobeit99
#123279 09/10/00 03:10 PM
Anonymous
Unregistered
Anonymous
Unregistered
I did the DRL fix to mine ... pull the jumper , slap in a relay & away you go !! I got my relay at a local dealer for about 28 bucks . Bill Jenkins might be able to get it cheaper , but I just ordered it & they got it for me in a couple days . Now I'm the only 'Tour with DRLs in my area (well , me & my bro. )
BTW - the relay will only go in one way , if that's what you were concerned about
"If you want to finish first ... first you must finish !!!"
[This message has been edited by TealTour95 (edited September 10, 2000).]
#123280 09/10/00 03:54 PM
N
NMC Offline
N
Can you tell me how the jumper was installed?
#123281 09/10/00 04:39 PM
Thanks folks. I'll order one. There is no jumber in my fuse block, just an open space where the relay plugs in. Looks just like the photo on the CEG web page.
Martin
Martin
99 Silver Frost SVT
#1060 of 2760
DRLs
#123282 09/10/00 10:06 PM
Anonymous
Unregistered
Anonymous
Unregistered
1) the jumper went from left to right of the relay plug in the power dist. box (when looking at it from the front)
**the left slot (marked #5 on my relay)runs front to back & the right slot (marked #3 on my relay) runs left to right in the plug**
If you jump the 2 together ... no more DRLs !
~~~see the jumper bar & plug here ... http://www.contour.org/cgi/showpic.pl?/FAQ/jpg/drl/DRL-good.jpg
2) if your car has a hole in the power dist box , and not a (white?) plug , then you're S.O.L. putting a relay in there .
~~~see the hole here ... http://www.contour.org/cgi/showpic.pl?/FAQ/jpg/drl/DRL-bad.jpg
