#122022 08/06/02 04:00 PM
ok after searching the archives i have afew questions about fuel injectors..
1. in one post Terry says that returnless fuel injection systems are top feed and return type have side feed. or words to that effect.
i have a 97/98 registered mondeo st24 (170bhp), on the barcode on the side of the engine it dates 06/04/97. i was looking in the haynes manual and it clearly shows top feed injectors on a return type rail. so i checked on my car and it has creamy white top feed injectors with the numbers 0280155771 cast on them. does anyone know if these are 16,17,or 19lb injectors.
2in another post some also say that the seating arrangement differs also.
is this in relation from top feed to side feed, or return to nonreturn type?
3 there is another post when someone fitted s/h 24lb return type injectors with links to pictures (that no longer work) apparrenty showing two types of electrical connection agian suposedly show differences between return and non return type systems. and as long as the connetors ar the same they state it makes no defferance wether you have return/returnless on your duratec.
i suppose what i am tying to establish is if i get a non return lower intake from BAT with top feed injectors, will it work ok with my top feed Return type fuel system/rail?
Mondeo ST24 with RSAP body kit.
17" DOTz's on 215/40/17 goodyear F1's (very good tyre)
EBC TURBO GROOVE FRONT AND REAR DISCS (rotors)(warped fronts exchanged under warrenty)
EBC GREEN STUFF PADS (voted no1 in uk performance ford tests)
k&N induction kit
throttle body butterfly mod
SHM HEADERS, Y & CAT
Custom Exhaust System
Ecotec Valve
more mods to come...
ice sony XR-M510 head unit
sony 656 changer(cdr/cdrw/cdtext compatable)
#122023 08/06/02 04:35 PM
Administrator
Administrator
Nope, no way.
The 98 to mid 99 Contiques on this side of the pond have top-feed, return-type injectors. Completely different from the ones Ford switched to once returnless was adopted.
-Lance
Lance Kinley
CEG Webmaster
95SE, "Official CEG Beater"
Quaife, SVT parts, ST200 wheels, SS Y-pipe
I perceive you to be a stand-up, rational individual...
