bizest Offline OP
I ordered a Magnaflow 14414 today to go in place of my resonator ('00 SVT), based on good reviews on another post.
Then I thought to myself, isn't the SVT exhaust piping 2.25" at that location? confused
Here are the Magnaflow specs:
Magnaflow 14414: Inlet/Outlet = 2" Core = 2.5"
Magnaflow 14415: Inlet/Outlet = 2.25" Core = 2.5"
Magnaflow 14444: Inlet/Outlet = 2" Core = 2"
Magnaflow 14445: Inlet/Outlet = 2.25" Core = 2"
Which one do I want??? confused Help me someone please. If I had to guess, I want the 14415, correct? I have to call back today if I need to change my order! eek
Thank you in advance!!!
"Bizest"
2000 SVT
Silver Frost / Midnight Blue
#489 of 2150
Current Mods:
KKM Intake
Removed resonator - TOO RASPY!
Rewired Fog lamps
Side window ventshades
Stereo System:
(1) Pioner E.L. Display CD player
(3) 12" R.F. HX2 DVC subwoofers
(4) Pioneer 6x8 plates in all doors
(1) R.F. 100 watts x 4 Amp
(1) R.F. 1100 watts x 1 Amp
(1) Lightning Audio 1 Farad Cap
I
I
It wont be a problem, The exhaust shop will be able to work around it. Plus Zap has an Svt and they go it to work on his car.
You don't want any of those resonators.
You ideally want one that has the same size inner diameter as it does inlet pipe diameter. 2.25" inlet/outlet & 2.25" core.
The 14415 is the best choice of the ones you listed.
2000 SVT #674 - Check it out!
