Posts: 85 |
Does cleaning the upper intake manifold require me to replace the gasket as well? or can I just re-use the old one? '00 SVT with 47k I would like to clean them tonight and I will take pictures if I can re-use the gasket.. otherwise I have to order one
2000 SVT #1633/2150 many mods, many more to come http://www2.gvsu.edu/~hafnerb/11h/car.jpg "If it doesn't fit, force it, if it breaks, it wasn't meant to fit in the first place."
Posts: 85 |
also, how do I go about removing those two black hoses from the top of the intake maifold just behind the carb. without breaking them?
Posts: 1,251 |
Pull the black houses out while holding down the collar with a flat screwdriver. They'll pull out a tiny bit on their own, but after that you need to hold down the collar. Also, make sure you pull straight or you'll snap one. They're brittle!
As for the gaskets, you'll likely need a new IAC and EGR gasket. The TB and UIM gaskets seem to hold up well.
Posts: 1,355 |
Leave the one going to the brake booster and just remove it from that end instead of on the UIM. Makes it one less to do!
I have the gaskets that I bought when I did mine, only had them on for about 2k. If yours are too bad to re-use, I'll sell you mine for like $10 if you want. Ford charges about $35 for both.
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
Posts: 5,805 |
Once you have the vac connections out of the intake ,remove the collar AND the 'O' ring is the brass sleeve or you will loose it and have an air leak on rebuild...just my 2 cents!!!!
Posts: 138 |
I just got mine UIM and LIM cleaned and I had 35,000 miles at the time. We (Stazi and I) cleaned them, scraped the gaskets and reused them because the looked still in very good condition. He used brake cleaner and Xylene. After cleaning them we started it up, and man did it hesitate and then boof, black smoke. After warming it up a little, we shut it off and he used a mister bottle and sprayed cool water in thru the TB, having to keep in reved up so not to stall with no MAF or any of that connected. After spraying the water it really smoked up and got all of that gunk out. You might as well change the spark plugs to while having the UIM off. Hope this helps. J.D.
1998.5 Silver SVT Brullen exaust off road Y kkm Aussie pipe FRW 5% mirror Cut shifter
Posts: 1,041 |
Had the same smoke and my engine wouldn't start for awhile. Scared me that I messed something up. But all was well... And it felt so much better. Check homepage for pics. But it wasnt long till these Damm Ford Engines went!(64,000 miles) Anyways Ill be back on the road someday. (3.0L)
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Posts: 138 |
Also after doing this you should change the oil, Speed Demon 64,000 miles?!! What happened? Did you just rage the **** out of it or what?
Posts: 85 |
After warming it up a little, we shut it off and he used a mister bottle and sprayed cool water in thru the TB, having to keep in reved up so not to stall with no MAF or any of that connected So I take it it was running when you sprayed the water in? Has anybody else done this? Because to me (Water+engin=F'ed up engin) but if its the best thing to do people let me know
Posts: 138 |
You have to warm it up and it like steam cleans the inside of your UIM and LIM. The water will just evaporate, it does not stay in you system. You will feel your UIM go from warm to pretty cold then go drive. And you wouldn't beleve the amount of black smoke that pours out of you exaust.
