Posts: 6 |
I just bought a new K&N intake kit and I am also looking into a new 65mm MAF from a cobra that is supposed to perform as well as an 80mm (seller said dyno's matched for both MAF's). He says I will need a 3 inch MAF adaptor to connect it. Does anyone know where I can get this part, or does anyone have one that I could buy? Thanks Post #1
Posts: 316 |
98 T-Red Contour LX V6 Mtx 106k miles 9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
Posts: 6 |
Will that one fit a 65mm one? Seems a little expensive...
Posts: 316 |
If you think thats expensive, try the other two places that sell them. $95 adaptor $59.50 adaptor They are even more!
Posts: 3,562 |
Factory Contour MAF is 70mm... BAT has them for $39.00 for the Contour MAF.
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 6 |
Alright-check check. This guy originally told me that he was sending me a 65mm MAF that performed as well as a 80mm one. Now he told me that the one he is selling me IS actually 80mm. So, I guess I need an adaptor for an 80mm MAF which is off a cobra. Will this new MAF make a significant change in power with the K&N kit that I had purchased or is it not worth the $ and better to keep the stock MAF?
PS- Its dirt cheap at $75 like new
Posts: 460 |
I hope you have an Apex-I or some other type of fuel air/management. You will need it.
Po-Jay
Ghetto Mods Galore! Quaife-CenterForce Clutch-Butterflies Rmvd and Replaced again-Bassani Exhaust w/custom "Y"-Pipe-33% of Mystery Mod-Pro M 75MM MAF-BNoon Optimized SVT TB-B+M Short Throw-ES Front Engine Mount-Some Aesthetic Crap- Blood,Sweat,Tears Do I hear the Fat Lady singing? 98 E0 Silver Frost (Is there any other color?) 172HP 149TQ W/Bad A/F Mix
Posts: 115 |
btw: with a dremmel, it is VERY EASY to modify the stock maf in order to work with a 3" filter....
time = about 10 minutes cost = 0$
2000 Cougar V6 MTX Black Visteon GFX Kit with Razzi rear skirts, Ground Controls, YoDude Exhaust, Ractive Filter, Custom Interior, Custom Loud Stereo, and more... See Her Here
Posts: 1,701 |
I recently changed to a 3 1/2" MAF adaptor and found it was a noticable improvement on a V6 with a few exhaust and intake mods. IMHO a 3" (76MM) MAF adaptor/air filter isn't quite big enough...
