Posts: 517 |
within the next 2 months i'm going to be getting a Quaife, Flywheel & clutch.
which flywheel and clutch do people recommend?
I've read about a few people with the fidanza flywheel, but does anyone have the Unorthodox Racing?
also, i want to get something better then an OEM replacement clutch (Grizzly) so in the future when i get boost, i don't have to worry about clutch issues... so whats everyones opinion? Unorthodox racing? Clutchmaster? Centerforce?
i was thinking about going with all Unorthodox stuff, but the UR flywheel is 12lbs and the fidanza is 11.5lbs and cheaper.
just trying to get some ideas... right now i'm leaning towards the Fidanza flywheel and the UR Stage 1 clutch
2000 SVT (silver) #1529 of 2150 ------------------- yeah...its modded
Posts: 93 |
Fidanza works well with Clutch Master stage 3 I heard some gusy got problem with Ram clutches and fidanza combo. I know Center Force has a clutch and flywheel combo maybe you want to look into it.
"You can turn a engineer into a sale man but, you can not turn a sale man into an engineer" "I have walk to the valley of Honda and death for that I should not fear no V-tech"
99 cougar,SVT manifold convertion, Tranny upgrade by Haines Motor sports (Quaife lds, Fidanza flywheel, and Clutch Master Stage 3 clutch) 18" Axis Se7ends,GC coiovers,sho sho Y pipe,Wilwood4 piston brake kit
Posts: 43 |
i have the Fidanza+CenterForce setup, its a great setup. had it for a month and can't find anything bad to say about it. centerforce run me for $550CND around 350US half the price of the UR. something to think about.
95 SE MTX Midnight Red Dual Extrude Honed SVT Intake Manifold / 65mm TB / SC Cold Air Induction / Ford Racing 9mm Plug Wires / Quaife Limited Slip Differential / Centerforce Dual Friction Clutch / Fidanza Flywheel / UR Underdrive Pulley / Custom Dual Straight Flow Exhaust / StreetGlow Sport Pedals / Tint / Pioneer Deck and CD Changer / 2 12" Orion XTR subs / 2 MTX amps(425&280watts) / Phoenix Gold Titanium Bass Cube and Wiring / Boston Acoustic 5x7's, and Rockford Fosgate Tweeters. Next: 19# injectors and chip Rebuilt engine @180,000 km Rebuilt tranny @215,000 km
Posts: 517 |
Hey Abwamo,
Did you get the Centerforce Dual Friction Performance Clutch for $550 canadian??
Posts: 43 |
JB automative $500+GST and rushed delivery. I got the managers disount price, my friend knows the owner. got the flywheel for $510 and they're worth every penny
Posts: 517 |
thanks for the info guys...i'll look into it.
Posts: 1,036 |
Showtime - I got the Quaife/Fidanza/Unorthodox combo a few months back. If I were to do it again I would most likely pick the Clutchmasters clutch over the Unorthodox. I have had good experiences with Clutchmasters in the past and the Unorthodox clutch makes funny noises sometimes which at times makes me unsure about the stability of the clutch all in all.
98 E0 Silver SVT KKM - Bassani - MSDS - BAT - ES - Unorthodox - HID - Dyna-batt - Koni - Ground Control - 17" MAS Italy Rodger - Quaife - Fidanza
"Every easy girl I have been with has been either a hosebeast or a headcase" - Pete D
Posts: 583 |
I've bought the
Quaife/Centerforce/Fidanza combination... LOVE IT!!
Centerforce $416 shipped Fidanza $366 shipped..
Thanks Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's* B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers. Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
Posts: 517 |
Thanks Eric where did you get your centerforce and fidanza for that price?
Posts: 583 |
Correction Centerforce $416 plus $10 shipping www.nopi.com or call Nopi DF988988? I think is the part# Man what a beautiful clutch.. Fidanza Flywheel www.monkeywrenchracing.com also $366 plus $10 shipping. Your Welcome!! Eric
