This passed weekend i cracked my oil going over a manhole. So I ordered a new one at my local ford dealership. Well wouldn't you know that the damn thing has these 2 baffles on the on the shallow side of the pan. Not only that it came with new bolts and gasket all for 9o dollars. Its a pretty good pick up especially if you are gonna change your y pipe. If you are gonna do this get some PB Blaster from your local car shop to losen up some of those nasty nasty bolts
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill| Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
