Posts: 456 |
As some of you may remember, I got the Koni Sport Kit and 18" rage Enduros installed.
My car has a A$$ high stance, anyone else and Why....????
BTW 96 Zetec
01 PORSCHE 996 ![](/ubbthreads/images/graemlins/smile.gif)
Merdian/Black
Full Aero
Fabspeed mufflers
Fabspeed CAI
B & M shifter
96 GL MTX Zetec 2.0 ![](/ubbthreads/images/graemlins/smile.gif)
White/Blue
Blaupunkdt Houston
K & N Drop in/Koni Kit
18"RageEnduros/Flowmaster 40 Series
Posts: 533 |
so you are saying the rear end is higher then the front? if so, i believe that is 100% normal with the koni kit.
-a
koni kit - hpp rstb
camber/plates - cf (yikes!)
polyroll resistors - TCA's
WR headers/ypipe -TB hiflow cat
SFC's - XCal2
-dreaming of 3L-
Posts: 5,143 |
Originally posted by 111R: so you are saying the rear end is higher then the front? if so, i believe that is 100% normal with the koni kit.
-a
tis... its the same with the stock suspension too, particularly the SE suspension. Its a better center of gravity for increased grip.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 3,867 |
Originally posted by AliasJerkâ?¢: Originally posted by 111R: so you are saying the rear end is higher then the front? if so, i believe that is 100% normal with the koni kit.
-a
Function before fashion.
'96 Contour SE
Posts: 1,978 |
Originally posted by supertouringmike: As some of you may remember, I got the Koni Sport Kit and 18" rage Enduros installed.
BTW 96 Zetec
The only thing thats gonna bring the rear end down is a set of eibachs.
Alex
'99 SVT Contour
