Posts: 363 |
Well I have had the MIL on for a while now and decided to get the codes scanned. Here's what was found:
-HO2S signal circuit malfunction: P0156.
-HO2S heater circuit malfunction: P0135, P0141, P0155 and P0161.
I find it very hard to believe all these HO2S's have gone for a crap all at once. Is it possible a fuse is blown somewhere to cause this or am I looking at multiple O2 sensor replacement ? Car seems to be running fine without any significant mileage change ...
98 Mystique GS V6 - K&N, projectors
91 Mustang LX 5.0L
00 Jetta TDI, Yay, I bought it !!
95 VW Getta TD - RIP: Nov.3,2005
Posts: 5,345 |
Originally posted by weasel: ..I find it very hard to believe all these HO2S's have gone for a crap all at once. ..
Me too. Check/change Fuse 13 (20AMP) for O2 sensors in the Power Distribution Box next to the battery.
Originally posted by weasel: .. Is it possible a fuse is blown somewhere to cause this ..
Yes.
1996 V6 ATX 96K miles
Posts: 197 |
Originally posted by weasel: Well I have had the MIL on for a while now and decided to get the codes scanned. Here's what was found:
Or you could also have one of the heater circuits grounding out the rest. I've seen that happen many times before when I worked at the dealership.
Have fun....
The ONLY 96 (engine) 3L
Build 'em fast. Spray 'em faster.
ricehatersclub.com
Posts: 363 |
Have fun, gee thanks !!! Well I did some looking and fuse 13 wan in fact blown. I replaced it and it blew again. I traced the first two upstream O2 sensors and didn't notice any wiring problems ( well I traced them into a loom ! ). Haven't checked the last two, but I doubt its a sensor itself. Any ideas where to look to find this ? Known problem areas ??
91 Mustang LX 5.0L
Posts: 1,788 |
Inspect the sensor harness to see if one is lying on the exhaust manifold and has melted.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 363 |
Will do ... tomorrow though. Raining like a SOB here.
91 Mustang LX 5.0L
Posts: 136 |
Disconnect the all 4 O2's, put a fuse in, if it still blows you have a problem in the harness. If it doesn't, plug 1 O2 in at a time until the fuse blows, when it blows that is the O2 you need to replace.
