Posts: 1,356 |
My neighbor is working on building another hotrod, this one is a 1947 Ford... The top is going to be fiberglass, but he wants it to be backed by wood paneling. Problem is, everything we've tried to stick the two together doesn't hold up when it goes out in the sunlight. Does anyone have any suggestions on what to use to hold the two together?
I think the main reason they don't wanna stick together is they both expand/contract at different rates, so it has to be something that would be somewhat flexible...
Any help would be greatly appreciated.
1999 Mystique LS V6
Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
Posts: 2,132 |
Different types of material expand and contract at different rates when they are heated and cooled. Something flexible like window or bath tub silicone might work because it stays flexible. I don't know how well the silicone will hold up in the heat of the sun.
Posts: 306 |
I was thinking maybe some contact cement?
98 CSVT Black
Alpine CDA 7995
Memphis 1000D & Alpine MRV T302
2 Orion 12's
HPP Rear Strut Bar
Posts: 1,882 |
Having replaced the wood floor in my boat (which was previously fiberglass covered), I didn't have ANY problems getting the glass/resin to stick. Does the wood have some sort of coating/finish applied to it? The boat has sat outside all this summer w/ the new floor exposed to direct sunlight and 107° temps w/ no failure or separation. Maybe he should lay down a layer of resin only as a base coat/sealer, and after that has dried, scuff it up and begin layering w/ glass and resin.
Posts: 5,810 |
Originally posted by 99Mystique ATX: My neighbor is working on building another hotrod, this one is a 1947 Ford... The top is going to be fiberglass, but he wants it to be backed by wood paneling. Problem is, everything we've tried to stick the two together doesn't hold up when it goes out in the sunlight. Does anyone have any suggestions on what to use to hold the two together?
A quality epoxy resin.
You can search the internet and buy it by the gallong but it may run you close to $100 for that much.
See My Mods
