Posts: 90 |
I have a guy thats going to do my 30L swap. He just did one for a kid on here. I talked to him and he said that he cant do the split port work to get the SVT(2.5 intakes ) to match, he said i should just use the 3.0L ones!! what do you guys think about that???
Posts: 587 |
Depends what you are looking for out of this 3.0L swap. You can get the 3.0L heads port matched to fit the intakes. You could also try to do it yourself. Some guys on here also do the port matching so they probably will chim in if that is what you are looking for. I with the svt intakes because it suppose to be the most power for the swap. It just depends on the money you want to spend as well. Give us some more information and we could give you some direction.
3L process done
Posts: 937 |
If I were going naturally aspirated I would do the split ports. The SVT manifold works well with this - and I like the looks of the stock SVT engine! It will also save effort with fuel line plumbing.
With a turbocharger, oval port all the way.
99 Tropic Green SVT, Tan Leather, 20K miles, "Nice Twin" (factory stock).
99 Tropic Green SVT, Tan Leather, 28K miles, "Evil Twin" (Turbo AER 3L and more in progress)
96 Red LX, Opal Grey Leather 2.5L, ATX, 22K miles
Posts: 5,810 |
Originally posted by carzyjay: I have a guy thats going to do my 30L swap. He just did one for a kid on here. I talked to him and he said that he cant do the split port work to get the SVT(2.5 intakes ) to match, he said i should just use the 3.0L ones!! what do you guys think about that???
I think it is easy enough to do the split port work that even you could do it on your own. Therefore I would wonder why he can't????
I'm doing a 3L right now with full P&P heads, split port conversion and such for a guy in GA. It's looking good so far.
See My Mods
Posts: 5,810 |
Originally posted by JEDsContour: If I were going naturally aspirated I would do the split ports. The SVT manifold works well with this - and I like the looks of the stock SVT engine! It will also save effort with fuel line plumbing.
Not really. Shape of the manifold with turbocharging is less of an issue. I think both will work equally well especially since the air is forced. And in that case, everything you wrote above is still relevant.
Now IMRC isn't really an issue with the turbo so that could stay or go depending on how the turbo is sized, piping choices, etc.
See My Mods
Posts: 90 |
i would love get a 03 04 motor and if i can buy a set of head that are port matched that would be great!! i will look for someone on here that does them. Thanks for the feed back, helps alot.
