Posts: 1,609 |
My svt when i jump in it and turn the key to the start position it will make this grinding noise and does not turn over (like when you try to start a car thats already started). But when I go to start it and turn the key to the on position then wait 3 seconds or so and turn to to the start position it starts fine. Any suggestions?
1998.5 SVT contour #5979 3L
1995 Mercury Mystique 2.5L auto, all ghetto fo sho
Posts: 166 |
new starter/solnoid( not shure on spelling)? thats what it sonds like it could be.....id start with the cheap fixes first
99' silver smokin' csvt
born on march 18 99' #1491 of 2760
burninrice no more
Posts: 1,609 |
LOL what is a cheap fix on this car :S
Posts: 5,143 |
Originally posted by buttersSVT: new starter/solnoid( not shure on spelling)? thats what it sonds like it could be.....id start with the cheap fixes first
Always do the cheap and easy ones first
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 1,456 |
Starter is cheaper than flywheel
Posts: 1 |
Hi mate I've got the same problem! Anyway, today I've changed the starter and it's not fun really. After puting everything back the car started great, I drove it a little just to get the air off the cooling system.
Unfortunatelly when I tried to start it later today I got the same noise! :nonono: I guess I'm missing teeth on the flywheel :cry: :help: I hope you'll have better luck!
Posts: 1,609 |
Originally posted by RPM: Hi mate I've got the same problem! Anyway, today I've changed the starter and it's not fun really. After puting everything back the car started great, I drove it a little just to get the air off the cooling system.
Unfortunatelly when I tried to start it later today I got the same noise! I guess I'm missing teeth on the flywheel I hope you'll have better luck!
Thats not what I like to hear
Posts: 5,143 |
Originally posted by starjammir: Originally posted by RPM: Hi mate I've got the same problem! Anyway, today I've changed the starter and it's not fun really. After puting everything back the car started great, I drove it a little just to get the air off the cooling system.
that wouldnt make sense bill... You have a brand new fidenza flywheel which might I add also has been lightened... If its already missing teeth I would be contacting who installed it.
TEIN H.Tech Springs
Posts: 5,345 |
Welcome, RPM . Before assuming the worst, check if the starter is aligned properly. You may just have not installed it properly.
1996 V6 ATX 96K miles
