Posts: 330 |
I bought an se with a blown engine (threw a rod thru the oil pan) and it came with an svt block.... Should i just swap the heads off the se on to the SVT block, or should i buy SVT heads off here for 275?
97 V6 ATX 20,000 Miles
alpine cda 9811
Alpine MRV-F357
hifonics brutus BX2000D
2 Kicker L7 15
I NEED GREY LEATHER DOOR PANELS!!!!!!
Flip out monitor
PS2
Spr-175a
SPR-69LP
SPR-57LS
60 Ft EDEAD
Posts: 5,143 |
Originally posted by contourdude: I bought an se with a blown engine (threw a rod thru the oil pan) and it came with an svt block.... Should i just swap the heads off the se on to the SVT block, or should i buy SVT heads off here for 275?
I personally would go with a full SVT motor, less complications on the install. Dont forget you need to put in high octane gas from then on though.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 7,117 |
Sell the good block & buy a 3L.
Posts: 636 |
Originally posted by TourDeForce: Sell the good block & buy a 3L.
+1, if I could do my car over again I would have never put another SVT motor in
-Mike
98 Contour SVT
Toreador Red #49 of 6535 Built on 3/25/97
WR Headers, Borla Cat-Back, Torsen T2 LSD, K&N Short Ram, S-AFC and Focus Shift Tower
85 Camaro
1969 358ci, 97 TA interior, 91 Z28 GrdEfx and Aero Wing 255rwhp
Posts: 197 |
If you need the 2.5 head gaskets I got a set of felpro. Cheap.
The ONLY 96 (engine) 3L
Build 'em fast. Spray 'em faster.
ricehatersclub.com
Posts: 329 |
Originally posted by CSVT#49: if I could do my car over again I would have never put another SVT motor in
Maybe this is off topic but I'm very curious why you say that. There's some other people here that have dropped in 2.5's rather than 3.0's and I think they've been happy. I've also heard of a few people that have regretted going with a 3.0, though most seem very happy.
Not trying to start anything, just genuinely wondering why you seem to regret what you did. It seems like you have people on both sides of the fence. I have a good 2.5 that I've been thinking of using after I'm done with my 3.0.
1998.5 SVT
I'm working on it.
WTB 2.0L Contique.
Posts: 7,117 |
Originally posted by 04marauder: Originally posted by CSVT#49: if I could do my car over again I would have never put another SVT motor in
Nothing wrong with an SVT 2.5, for sure. I think the idea is when you drop in a 3L, you get more HP & Tq for less money than getting hold of a rather limited availability SVT 2.5 engine.
I've seen the SVT 2.5 priced over $1700 for a used stocker, but you can get a low mileage 3L for under a grand pretty regularly. I think Bill J had some NEW ones available for uner $800 at one time...
Redneck Troll
Redneck Troll
Posts: 2,621 |
Originally posted by AliasJerkâ?¢: Originally posted by contourdude: I bought an se with a blown engine (threw a rod thru the oil pan) and it came with an svt block.... Should i just swap the heads off the se on to the SVT block, or should i buy SVT heads off here for 275?
There's really no difference in the SE heads vs. SVT heads other than extrude honed ports. The thing is, the ports are so straight and easy to access, it's easy to port the SE heads out to SVT specs (or beyond). SVT heads are a waste unless they come with cams.
I vote for 3L though, no matter what way you build it (cheap-o hybrid, full 3L, or bastard-ized version anywhere inbetween). How could anyone be upset with an extra 20-30 HP and 20-30 foot pounds of torque minimum? The only people I've ever seen complain about the 3L swap are people that had no buisness doing their own engine work in the first place, 2.5 or 3.0, let alone attempting a swap of any sort.
http://www.bnmotorsports.com
