Am currently working on repairs to the IMRC on my UK Mondeo V6 Ghia (Duretech). In the process I have found that the Fuel Charging Wiring Loom is TOAST - all of the insulation has flaked off from the IMRC connector back to half way along where the wires run under the UIM (Upper Inlet manifold)
Fuel Charging Wiring Harness is a short piece of loom that connects:
Inlet manifold Runner Control (IMRC)
Engine Coolant Temperature sensor (ECT)
Ignition Coil Pack
Crankshaft Position Sensor (CKP)
Camshaft Position Sensor(CMP)
Heated Oxygen Sensor(HO2S)
It has plugs where it connects to the various sensors above.
It runs from a connector block on main loom in the engine bay just in front of the driver(UK)or passenger (USA), under the upper inlet manifold and out the other end by the Throttle Body and then connects to the IMRC etc.
Have Contacted Ford NZ and this part is OBSOLETE...they suggest only option is to rewire.
DOES ANYONE KNOW OF A SUPPLIER IN USA WHO MAY HAVE OLD STOCK - I CAN PROBABLY GET THE PART NUMBER IN NEED. OTHERWISE IT LOOKS LIKE I NEED ONE OUT OF A WRECK.
