Posts: 3,076 |
Anybody use the Easton Synergy shafts? I just snapped a one-piece Synergy II right at the blade durring a game. I can easily cut it and continue to use the shaft with a replacement blade but the shaft is slightly smaller (and I mean very slightly) than the aluminum shafts I am used to and have replacement blades for. What blades will fit the Synergy shaft?
2000 SVT Black/Tan #1633/2150 (a few mods)
Alpine: CDA-9835, MRV-F540, MRD-M550
PG: TANTRUM-X 6.5 COMP all around.
Some people wear Superman pajamas. Superman wears Chuck Norris pajamas.
CEL currently: Off
Posts: 1,051 |
I am not sure, but I believe they make a replacement blade for such an ocassion. I would look on their site and see what they say
Built April 18th 1998 #5770 of 6535
Reborn: July 11, 2004 3L and gone again 12/13/2005
new ride: 98 Silver frost SVT with all my old goodies!!!!
Posts: 681 |
I can go outside and check my stick which is in my contour, but if I remember correctly almost any standard sized blade should fit in the shaft. That is as long as the size wasn't altered due to the break.
99 Silver CSVT
Posts: 1,341 |
first off how long have you had the stick......they all have a 90 day warranty....that is if you have the reciept to prove it. I would just ask your local proshop though just to be safe......
now that I think about it it might only be a 60 day........
Posts: 7,012 |
Oo (xxx)oO
o xxxxxxxx o
Posts: 3,076 |
I thought it was 30 day, I remember because I was turned down when I broke my z-bubble shaft after about 45 days. I went up against the boards with a big goon and he lost his footing and fell back right on the center of the shaft. Sad thing was it was the 2nd game I ever played with it.
But I looked on the synergy shaft and there is a warranty statement but no time specifics other than "warranty will be determined by Easton"??
CEL currently: Off
Posts: 777 |
I remember I had a synergy that had broken, and someone had put a regular easton blade on it. I didnt do it, I bought it like that, but I think the person did some modification to the blade to make it fit, probably sanded it down a little.
Posts: 7,012 |
my little brother broke 2 easton Z-bubbles in a week. the second one was on the crossbar after the other team scored. both were replaced for free without question.
Oo (xxx)oO
o xxxxxxxx o
