#121563 07/23/02 07:53 PM
I forget if this got posted but for some of you looking for Ideas.
Now dont go yelling at me because it's made out of aluminum. Weapon-R.Com
At least its something.
You can check my page of a Cold Air Intake, and the 3" aluminum pipe was ceramic coated by Jet Hot. I still need to do some updating. Im also gonna fabricate a heat shield blocking off my filter from the tranny. My current 3.0L swap is taking up all my time though.
Silver 98 SVT Contour E0
#4124 (Currently on Life Support)
Built 11/97 Bought 1/98
Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods
Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI
"Come Out...Come Out Where Ever You Are"
http://www.geocities.com/speeddemons19
#121564 07/23/02 08:29 PM
$175? eek
-Rob- '98 E0 Contour SVT #897, T-Red. FOR SALE: '98 E0 CSVT #2663 SilverFrost; stock & in very good condition. $7,800
KKM & BAT Intake Pipe, DIY cool air intake, Resonator deleted, TH fix; short shifter, rear spoiler, hood struts, fog mod, pre-98 sails, dings removed, A4 side-markers, clear head-light corners, T-red chrome front & back. Aussie Bar waiting for installation.
"Monkey is my business...and business is good!"
#121565 07/23/02 08:36 PM
Yeah definetly something that you can make
but considering Sho Shop sells CAI for $130 or so...
#121566 07/23/02 09:27 PM
$175 for an aluminum box, lol. I bet you could throw in a totally stock 'Tour, closed hood dyno and it would take away a measurable amount of horsepower. If you want to put a box around an open air element why not use the stock one?
Buy it, wedge it somewhere in the engine bay where you don't want heat, and use the intake hole to fill it with ice.
#121567 07/24/02 04:02 AM
Hmm yummy. A $175 convection oven for your air filter. :rolleyes:
Overpriced Garbage IMO.
2000 SVT #674 - Check it out!
#121568 07/24/02 06:08 AM
3
3
Try running a tube of cold air to it and see how much of an oven it becomes. I think it would work well if it was fed a cold air source. My brother had a set up similar to that on his 2000 GTI VR6 and the intake temp according to the computer was 10 to 15 deg over outside air at any speed over 15mph. I belive that was a 60 degree difference from the underhood temp.
Roger
98 SVT E0, Black
Blown motor, help on the way......
97 GTI VR6, Green
#121569 07/24/02 11:59 AM
Roger, the point is not the design of it, but the material choice. If you want to keep your air filter cold, you want to keep heat away from it. They chose aluminum, probably because it is inexpensive, and because it looks nice and shiny under the hood, and someone can annodize it for a show car. Because that is why you would buy it, because it would stick out with a fade annodization and racing stickers.
#121570 07/24/02 02:59 PM
And as 3.0LSVT said, running the cold air tube would greatly reduce our first thought of Hot Aluminum. I dont think it's the best choice. Even I enhanced my aluminum cold air intake.
#121571 07/24/02 05:49 PM
Just get an K&N drop in filter, keek the stock housing with the airbox on, if u want make an extension running into the fender, so it has sort of a ram air effect, and buy an intake insulator from Summitracing. Its a tape that you put on which keeps the heat out. and there wour CoLD AIR INTAKE !!! tape i think is like $50 and K&N is around the same price.
