I was using the AWSF22 in my car. I took them out after I "modified" them with some little bits of aluminum (not plug related) to put the colder NGK plugs in. I'm not real comfortable with a plug that's not double plat, so the NGK are only a stop gap. Now that I know it wasn't the plugs' fault, I'll replace them with the 22s soon.
The link didn't work for me, but I bet the 5.4L app the 22s are in is one with a blower.
Cold plugs are used when compression is increased or boosted engines (anything that increases cylinder temperatures). The increase in the 2000 SVTs compression warants the use of the 22. Supposed to be stock, but many people have reported 32s from the factory on 00 SVTs. Easy to see the mistake, since the non-SVT Duratec for 2000 used the 32 stock.
FWIW, the 98-99 SVT, 95-00 non-SVT, and Taurus 3L Duratecs all use the 32 plug stock. I haven't specifically checked the Escape Duratec, or the Lincoln and Jag 3L Duratecs, but I wouldn't be surprised if that was the case for them as well.
