CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Tourige: Originally posted by 5speed3.0SE�®: car was suneil's... it now sits in our driveway next to the 3L under the ownership of my father.
Is that the True Blue one with the Front mount?
Black.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 1,943 |
Originally posted by Loco4G63: Originally posted by Tourige: Originally posted by 5speed3.0SE�®: car was suneil's... it now sits in our driveway next to the 3L under the ownership of my father.
Black.
lol, exactly. get with the program ...
the 3.0L
oval port 3.0L '98 midnight blue se
Posts: 3,637 |
Black.
Oi!
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 227 |
i looked it up and down many times on his site. it is a nice car, for sure. i was gonna duplicate his build but i decided that i am going to stay with nitrous. turbos are sweet but not on my 100 mile round trip to work and back....
1998 CSVT
NX stage 1 ford EFI kit
MSD dis-4
B&M short throw
K&N short ram intake
Fsvt Euro 17's
Trubendz 2.5" exhaust
Spec stage 3
249.9 HP 258.2 TRQ clutch slipping the whole time
Posts: 2,097 |
I kind of just wanted to keep quiet until the big day... oh well we'll see what happens.
98 E0 SVT with some stuff
Posts: 2,097 |
oval 3.0 balanced, stock bore 9:1 Diamond pistons...3L upper (alum) and lower keeping 2ndaries 3L cams as well(custom modded LIM) Minor port/polish heads, GT TB ported, custom built turbo kit w/ MSDS headers, 750 cfm Intercooler, custom exchanger, 42# injectors, 80mm Lightning MAF, 3in exhaust no cats.
Just some specs for your.
Another thing I thought of is this will be a custom kit v. a production kit.
I am not tooting my horn by the way...that's why I have kept to myself b/c I didn't want to come back and say I only did xxx hp. Please keep that in mind.
Posts: 2,728 |
Originally posted by TRicker: turbos are sweet but not on my 100 mile round trip to work and back....
Whats wrong with a turbo in that case? If you're out of boost you generally pick up a mile or two more per gallon of gas and if you aren't on it nothing is going to pop because of the turbo.
'03 SRT-4
50 trim turbo + support
Posts: 431 |
I am sure your setup is very nice too. Anybody who goes through the entire setup like we did should easily see 400whp in my opinion is to much for out car. I beleive you will run in to a road block like me with the MAF I most probably will outflow the lightning one since i was using 75% off the MAF with just 12 psi. Fuel for me seems to be not an issue like others faced with the 42lbs.
Warmonger has got this thing uncontrollable at this point I will be so curious to what I am putting down right now with just 14 psi.
I think the major differences between our setup is fuel supply, CR, cylinder volume and the trims are slightly higher for you.
I also have 3lb spring in my tial wastegate that doesn't allow my boost to come in so quick. It is a smooth pull since more than likly my wastegate is opening prematurly on low rpms. But it is advantage to have the power more up top due to the traction issues. BUt at 4K I am at 14psi and the pull never stops to redline. Which I am sure we will see different dyno graphs since i am using the SVT cams too.
But unless somthing bizarre happens like a hurricane comes or meteor Hits Earth. I will have a dyno for Sept 5 ( 7 days ) and a video to go along with it. Thanks for the support and info guys there is no way in hell I could have built a car without the forum and foremost Warmonger for his great tuning and advice.
Let me know when there is a meet coming up I will make it there so some CEG die hards can get a ride in the car and see up close what makes us unique from most FWD cars.
99 SVT #198 blk/blue
Spec 3/quaife/stage 2 shafts
T3/T4 fully built 3.0
ported heads
water injec./intercooled
13.2 @ 107 mph
clifford alarm and turbo timer
koni struts H&R springs
intercooler for sale
Posts: 2,097 |
Hopefully my dyno won't be too far behind...although the advantage that I have is the altitude...hp is corrected here and I won't be pushing the stress or fuel to extremes as I would at sea level...I live near Denver...the "mile high" city. So I am crossing my fingers that it will work out that way. Good luck to you on the dyno!!!!
Posts: 9,196 |
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
