Posts: 504 |
I know an OIL LUBE AND FILTER basically changes oil, filter and lubricates the chasis, but this weekend will be the first time I change my own oil and I was wondering how would I do the lubricate the chasis part? And with what product?
1998 Mercury Mystique LS
- Looking for SVT EXHAUST, SVT Rear bumper (silver frost) and ANY rocker mouldings (side skirts)
Posts: 9 |
well depending on if anyone has replaced any of your front suspension parts with cheap ones then you should be able to grease the upper and lower ball joints, and your inner and outer tie rod ends. however if someone has replaced any of that stuff with cheap parts a lot of the time the cheap parts are non greasable which means they dont have grease fittings on them. but go to your local napa or autozone and buy a tube of grease and a grease gun and you can lube all of those.
Posts: 4,693 |
A lube job is a carry over term from many many years ago when it was necessary to grease several fittings under the car related to suspension and steering. It is uncommon today for any of those same parts to need grease anymore. They are built with materials that tend to be self lubricating, packed with much superior grease, and what grease there is much better sealed into the component.
Today, the term "lube" usually means nothing more than checking and topping of fluids when it is performed along with an oil change.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 504 |
Originally posted by Big Jim: A lube job is a carry over term from many many years ago when it was necessary to grease several fittings under the car related to suspension and steering. It is uncommon today for any of those same parts to need grease anymore. They are built with materials that tend to be self lubricating, packed with much superior grease, and what grease there is much better sealed into the component.
bleh lol, thanks for the save there Jim. You always seem to save my ass .
Posts: 21,653 |
Originally posted by slvrsvt: you should be able to grease the upper and lower ball joints, and your inner and outer tie rod ends.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 980 |
Originally posted by Kremithefrog: Originally posted by slvrsvt: you should be able to grease the upper and lower ball joints, and your inner and outer tie rod ends.
+1
2000 Mystique LS
Duratec 2.5L MTX
Posts: 3,816 |
Originally posted by Tisby: Originally posted by Kremithefrog: Originally posted by slvrsvt: you should be able to grease the upper and lower ball joints, and your inner and outer tie rod ends.
+1
Maybe if you don't have Ford parts
I know the ball joints we put on my 96GL (you know, the ones where you use the original LCA and grind off the old ones) had a grease nipple on them.
Posts: 21,197 |
Yes. The Ford replacement ball joints have a zerk fitting so that it can be greased. They don't come from the factory that way. There aren't any zerk fittings on anything on this car from the factory.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 21,653 |
Originally posted by todras: There aren't any zerk fittings on anything on this car from the factory.
Glad I wasn't going crazy.
98.5 SVT
Posts: 246 |
Coming from A walmart Grease monkey almost all of the newer cars 95 and up don't have grease fittings. Some of the bigger GM vehicles will have one or 2. The newer ford trucks are lucky to have 1 on them. Gm on the other hand have around 7-13 on there trucks big and small. I do get some aftermarket parts that have fittings on them like what was said before.
99 Contour SE Sport
