Originally posted by nics420:
1. thinking about pro flow 75mm maf/
2. sho shop 63mm throttle body/
3. has anyone tried the two?together?
4. whats up with that butterfly secondary from sho shop?
5. is any one running bosch plat 4's?just need some info.
1. Get it. It is a great unit.
2. Optimize the stock unit. A 65mm has shown power loss on even moderately modified SVT's
3. n/a
4. It's a bored out stock piece. You'll need much better breathing (other areas) before you need to worry about enlarging the LIM significantly more than the UIM & head ports are.
5. Skip them by all means! Install a set of Autolite APP764's or Motorcraft AWSF32PP. Step to the colder AWSF22FS plugs if you get a chip.
The car is a blast...
Oh and your best source of Info is in the upper right hand corner -
HERE!
