ok when looking down to the ground on the manifold I see this big bulge it looks like a cat.Is it one? is the muffler looking thing under the middle of the car a muffler? if so why does this car have two mufflers? what do i need to remove modify for better air flow? also speed limiter. 105 is really slow!!! I was reading in the haynes manual that there is a relay under the dash that controls this,yet every where else they say it is managed by the ecu. I really want to get rid of this stupid limitation.
last thing i am going to see what i can do for turbocharging. I have a quite bit of knowledge in this area and i have the T3 turbo from the 240 left over. First compression needs to get lower , 2 head gaskets should solve this. since there is no ecu made for controlling a turbo in contours a turbo controller will need to be added. Also intercooler,wastegate, detonatioon sensor,air fuel monitor. i will keep you posted on how it turns out
1995 Zetec
Mods: CTA cai,dynomax super turbo muffler,front and rear strut tower braces,soon to come: removing resonators,superchip,maybe turbo!!
Also have 1990 nissan 240sx Mods: 1998 Silvia red top conversion; SR20DET twin cam enigne, X-Track 6 speed, Nismo Clutch, Koni coil overs, Skyline calipers and rotors, T32 turbo, AEM cai,energy suspension bushings, Tokico sway bars, Nismo Strut tower braces f/r, HKS SS BOV,Blitz boost controller/turbo timer. MSD dis igntion system,carbon driveshaft,28lb injectors,800lph fuel pump,oil cooler, KKK intercooler 12.36@132mph
